1992 3vze idles issue
Old Jul 11, 2018 | 07:36 AM
DSullivan's Avatar
So i have a 3vze, manual, 4wd that i just rebuilt, had to get a sleeve put in and new pistons, rings, bearings and alot of other new parts. Im having an issue where when i crank it the idle is maybe seven hundred but as it warms up it gets higher and higher until its up around 1700rpm and wont come back down. I can tap the gas pedal and it will come down just slightly but then go back up. Any ideas as to how to fix that would be great. thanks
Old Jul 12, 2018 | 05:51 AM
DSullivan's Avatar
No body have any suggestions or theories?
Old Jul 12, 2018 | 06:22 AM
scope103's Avatar
When you set the idle speed http://web.archive.org/web/201501160...e/64tuneup.pdf (page 16), what did you set it to?
There are several adjusting screws on the throttle body. Does the throttle close all the way? Is something catching?
captainslow
Oct 14, 2017 02:18 PM
Brandon Dodson
Mar 31, 2017 03:37 PM
mcfly6667
Mar 24, 2017 12:32 AM
