Intermittently loosing Power Steering
Old Aug 8, 2018 | 10:38 AM
abalagtas's Avatar
Hi *,
I'm intermittently losing Power Steering. Reservoir is full no leaks. Do you think bleeding will solve?
Old Aug 8, 2018 | 10:48 AM
scope103's Avatar
I don't.
Are you sure your belt tension is correct?
http://web.archive.org/web/201310210.../2troubles.pdf
Old Aug 10, 2018 | 11:34 PM
wyoming9's Avatar
Red face
blockage between pump and reservoir causing intermittent failure
Loose belt
Key on pulley shaft sheared allowing pulley to slip at times
kaiowa99
Mar 29, 2011 04:33 AM
bkn
Dec 8, 2010 06:53 PM
crown7
7
Jun 20, 2010 04:10 PM
checkmate26
Jan 12, 2009 04:15 PM
loacyota
Mar 16, 2008 01:33 PM
