General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
loosing all electrical power when turn key
Old Jun 20, 2010 | 10:58 AM
crown7's Avatar
just put in my new engine in 85 4 runner. everything seems to be hooked up perfect but when i turn the key to start i loose all power. after about two minutes it comes back, like something is being reset. any ideas. 22re.
Old Jun 20, 2010 | 02:33 PM
myyota's Avatar
Check the power wire from the positive battery terminal to the fuse box by the battery, if this wire is bad or broken you will loose power to everything.
Old Jun 20, 2010 | 02:37 PM
DeathCougar's Avatar
Thing thing happens when a connection is loose. Check for corrosion, and proper grounding. Usually its from a loose connection.
Old Jun 20, 2010 | 03:05 PM
crown7's Avatar
ya ive checked that wire seems to be good. Have checked grounds and seem to be good one i was not sure about so just added another with no luck. the 80amp fuse the power wire goes to wont come out so its very hard to check without mutilating the box. so its making me think it has something to do with that. Any other suggestions?
Old Jun 20, 2010 | 03:26 PM
crown7's Avatar
One more question. what is it that resets to get power back? like i said earlier after a amount of time power mysteriously comes back. there has to be something reseting?
Old Jun 20, 2010 | 03:37 PM
myyota's Avatar
i don`t know what would be resetting itself after you turn the key ?, but to get the 80 amp fuse out you push the locking tab over a little bit with a screw driver and then push the fuse and holder out the bottom of the fuse box, the fuse is bolted in place. Have you checked the battery cables to make sure there good ?, they can look new on the outside but be bad on the inside. What about the battery, are you sure its good and is fully charged ?.
Old Jun 20, 2010 | 03:45 PM
The 80 amp fuse is bolted in. You have to remove the carrier that holds it in, THEN undo the bolt that holds it into the carrier. It comes out the bottom, like Myyota says
Old Jun 20, 2010 | 04:10 PM
crown7's Avatar
thanks for all the help guys. sometimes you just need to recheck the simple stuff. Man i feel like an idiot today! Tomorrow is a new day i get to start trouble shooting fuel system, for now im going with fuel pump. Thanks again.
jasonty
41
Dec 23, 2018 01:00 PM
gary4runner
Sep 24, 2015 12:53 AM
icentropy
Jul 14, 2015 10:23 AM
ZONAYODA
Jul 13, 2015 07:17 PM
smiley52
Jul 11, 2015 05:16 AM
