General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Bad ECU on 1999 4runner
Old May 27, 2010 | 07:56 AM
Brettski's Avatar
My check engine light turned on and I had the codes read at a dealer. The codes said that my front 02 sensor was bad. Replaced the sensor and reset the code. Light came back on again and now the code is saying that the sensor is over heating. The dealer is saying my ecu is bad and they want to replace it for $1200. Does this sound right?
MAF sensor was replaced also.
Old May 27, 2010 | 08:02 AM
j-man's Avatar
just take in a bottle of vaseline to them before they charge you for a new ecu......stupid dealers. Why is it that people dont go get 2nd or 3rd opinions? jeez.
Old May 27, 2010 | 08:32 AM
vital22re's Avatar
totally a bro
get a second opinion
Old May 27, 2010 | 08:41 AM
DeathCougar's Avatar
I would get a second opinion before you drop $1200. Dealerships love to "parts swap" instead of diagnose the problem correctly.
I have seen this problem before in vehicle, and the most common problem seems to be the catalytic converter. That is also an expensive option, but personally I would rather fix one spendy problem than throw $1200 uselessly at a truck and still have a problem.
In my experience working at this wrecking yard, in 9 years I have never sold an ECU for a 99 4Runner, and have zero calls.
Old May 27, 2010 | 08:48 AM
vital22re's Avatar
totally a bro
if the sensor is "over heating", which i've never heard of ever before, How is it overheating? from electrical overload? or from the cat being backed up? Gotta ask why.
Old May 27, 2010 | 09:04 AM
Brettski's Avatar
Thanks for the help! The exhaust smells like rotten eggs so I think it is the CAT. I have been searching all over the web for information on a bad ECU and can find very little resources. Truck is running fine but I need to get an emissions test for new plates here in Colorado. It won't pass with the light on. If I change the CAT what do you guys suggest for a new one?
Old May 27, 2010 | 09:12 AM
vital22re's Avatar
totally a bro
I've got a magnaflow high flow cat and i passed the sniff test and my 3.4 swap isnt' throwing any codes for it.
Old May 27, 2010 | 12:22 PM
This is a TELLTALE sign that the cat is bad. Check here on YT for similar stories.
Old May 27, 2010 | 01:10 PM
Brettski's Avatar
Well... just got back from a second dealer that had a look. They were more informative regarding the issue. They tested the wiring from the 02 sensors back to the ECU as the only reason the 02 sensors would be heating up (both front and rear) and have a code is if the wires were grounding out. The wires are fine. They suspect the ECU is also the problem because it is not normal for both 02 sensors to have the same heating code. They said that each 02 is on a seperate driver on the ECU. Advice???
Old Jun 11, 2010 | 08:22 AM
tunnelmotor99's Avatar
Usually when an ECU goes bad it throws lots of weird codes, so they may be right in saying it needs one.
Old Jun 11, 2010 | 08:26 AM
Kiroshu's Avatar
If the cat is bad it "can" overheat the O2 sensors.
Old Jun 11, 2010 | 08:30 AM
Brettski's Avatar
Update. Bad ECU was the problem. Not a cheap fix @ $1000.00.
Old Jun 11, 2010 | 08:31 AM
Kiroshu's Avatar
^Eww lots of money... Glad its fixed
Old Jun 11, 2010 | 08:34 AM
$1000?!?!
Should have called Nix99, i hear they have them for much cheaper.
Old Jun 20, 2010 | 10:39 PM
Ron Helmuth's Avatar
hope this was not the same part number...could have saved a boatload of cash looking over on Marketplace
https://www.yotatech.com/forums/f109...5420-a-213196/
snosurfer
3.4 Swaps
Aug 15, 2024 02:11 AM
icentropy
Sep 16, 2020 02:47 PM
Daneums
Aug 20, 2015 05:36 AM
cyclist231
Jul 7, 2015 12:56 PM
