RF1A Transfer case bearing numbers
Old Jul 1, 2018 | 06:57 PM
millball's Avatar
Hi I am assembling a 4.7 gear drive case to put into my '95 V-6 Runner.
I am changing out some of the ball bearings in it and I'm having some trouble cross referencing and laying hands on the front drive output ball bearing.
I bought a Nachi 6307N bearing, thinking it was correct. 35x80x21 (MM) with snap ring groove. Turns out that the front drive output gear wants a 30x80x21 bearing with snap ring groove.
The old bearing is marked NSK 6307N on its outer race and B30-120 on its inner race. It is actually 30x80x21 with snap ring groove. NOT 35mm like my Nachi 6307N.
If I am not mistaken, the Toyota online catalog (Lakeland Toyota) says the front output bearing part number should be:: 90363-30014
The SKF master catalog crosses this number to 6307NRJ. The online specs I've been able to find indicate that 6307NRJ bearing should have an inside diameter of 35mm???? WTF???
Anybody got any other bearing numbers, or insights that I might use to find to the correct bearing??? Thanks.
Old Jul 2, 2018 | 08:05 AM
coryc85's Avatar
millball - well, I just checked Marlin crawler and they only sell 2 tcase bearings individually (they do have a full case rebuild kit by the way) the input bearing and a counter shaft bearing, they don't sell the front output bearing individually and their full kit does not mention part numbers.
Old Dec 19, 2018 | 07:27 AM
millball's Avatar
As a follow-up to this thread. B30-120 is the bearing number for the RF1-A transfer case front output shaft bearing.
As an additional point of interest, some transmission parts purveyors call the RF1-A transfer case a W100 transfer case.
Old Dec 23, 2018 | 01:04 PM
SkeenMachine's Avatar
6307....wrong bearing.
I have the same problem finding the correct 6307 bearing. I’m putting the Marlin 4.7 gears in and that bearing needs replaced. I ordered a 6307 from Napa, Rock Auto and Marlin Crawler. All wrong, larger bore size. I talked to the guys at Marlin Crawler for a while and they assured me they had the correct 6307 and not the 6307 C3 one.... ordered it....and just received the wrong bearing from them yesterday. This is such a pain. I like Marlin Crawler, but they seem to mess up almost every order I make.
Old Dec 23, 2018 | 03:30 PM
millball's Avatar
6307 and 6307 C3 are identical bearings, for all intents and purposes. C3 just means that the bearings internal race/ball/race clearances are slightly larger than the same bearing of normal clearances.
This makes such bearings closer to normal clearance when tightly press fitted to shafts. Means nothing in a manual tranny, or transfer case.
I SAY AGAIN::::: The correct bearing for the front driveshaft output is:::::::: B30-120. Every one I have seen, so far has been an NSK Made in JAPAN 30x80x21 MM
They are not so easy to find. I got a couple thru a Tucson tranny parts supply outfit. The 6307's that don't fit can be got dirt -cheap. I had to pay near $60 apiece including shipping charge for the correct B30-120 NSK bearings.
Old Dec 23, 2018 | 05:08 PM
Thanks for your help I SAY AGAIN.
Old Dec 23, 2018 | 05:15 PM
scope103's Avatar
Thanks. This is just the sort of stuff for which YotaTech is terrific.
...If I am not mistaken, the Toyota online catalog (Lakeland Toyota) says the front output bearing part number should be:: 90363-30014 ...
Through Toyota: $114 https://parts.lakelandtoyota.com/p/_...036330014.html
...The correct bearing for the front driveshaft output is:::::::: B30-120. ... I had to pay near $60 apiece including shipping charge for the correct B30-120 NSK bearings.
From Singapore: $17.29 https://www.fitinpart.sg/index.php?route=product/product&product_id=596526 (Made by NSK. Note the part number and the Toyota x-ref)
Shipping from Singapore will add some (unless you LIVE in Singapore), but it might be less than $60.
Old Dec 23, 2018 | 11:49 PM
ev13wt's Avatar
5 Year Member
I used the marlin full rebuild kit (Australian brand).
I'd send you my old t-case front output ... but...
Old Sep 11, 2020 | 11:16 AM
buzzfast's Avatar
Here is the part # for anyone that may need future help - 9036332006
Took me some time to find it, ordered from my local dealer no problem
Old Sep 11, 2020 | 07:39 PM
millball's Avatar
Uh, No. Your number is is for the countershaft bearing.
NOT the front output bearing. NOT.
Your 90363-32006 countershaft bearing is: SKF 63/32 NJ.
The correct R1A front output bearing number is: B30-120 NSK
The 63/32 N type bearing is fairly common and made by numerous makers.
The B30-120 bearing is only made by NSK, so far as I have been able to determine.
Here is a handy link to the SKF master interchange, most Toyota factory numbers can be crossed over here::
https://grupodoyma.com/catalogos-web...NTERCHANGE.pdf
Old Sep 14, 2020 | 09:06 AM
buzzfast's Avatar
Here is the correct # 9036330014 then, the parts guy wasn't any help apparently, had to dig this up online
trying to find this B30-120 is very difficult
Thanks for the link
wrenchtech
Feb 6, 2019 06:58 PM
Regency
Sep 24, 2015 07:23 PM
yoterr
Jan 14, 2010 01:14 PM
simpsons721
Mar 26, 2008 03:49 PM
Toyo_Master
7
Feb 29, 2004 07:38 PM
