- Cylinder Head
- Larroc's $70 Bikini top writeup
- Rear disc brake conversion???
- Not sure exactly what it is, but something doesnt look right
- 4runner seat to ex cab???
- project on the go
- throwout bearing
- Bed liner on the rocker's = DONE! pics included ( 56k dont even try )
- I need some help with my swap please!
- Really interesting sound from air intake...
- Engine miss,stumble 22re Egr issue
- I Bought a
- small engine question
- How to change CV axles?
- saggy rear
- Gas!!!
- new gaskets?
- Timing chain
- o2 sensor / Cat question
- popping sound in the front. help!!
- Battey losing charge, short circuit?
- overheating after mud run
- head gasket.....engnbldr?
- Rear End Gear Ratios
- Dash light?
- Installed a Cb radio.
- bedlining rocker panels
- Broke wheel stud
- ADD front third? Picture.
- mass air flow
- aftermarket engine oil cooler Q's for 3vze
- 92 pick up
- Got a new truck, so time to say goodbye...kind of...
- My Truck Got Wrecked #$%@! By Another Toyota!
- trail rig almost didnt make it home on madien voyage!! sucked in water
- 89 Decals
- Bedlining the interior - Wires everywhere?!
- Getting stuck in 4Lo...?
- Help!
- gas mileage?
- O2 Sensor Stolen or Missing...
- 2wd suspension questions
- Does chrome get you home?
- OOPS! pulled the distributor....
- hard warm starts
- Did I break a C-V?
- approx. cost of sandblasting frame
- How not to end a day of wheeling
- Yakima racks goin on
- Like my new look?
- weird wheel size? 31x10.50xr15 help
- 22re swap
- replacing calipers rotors and pads.. TROUBLE!
- How to Remove Spare Tire Underneath?
- K&N... good or bad?
- Lost 3.5 quarts of oil, and don't know where!
- v6 3.0 camry mass air meter
- Where does your Temp Gauge sit??
- Muffler sound
- toytec 2in lift on 92 4runner
- V6 transfer case e-brake
- SUMMER is here!! .. on go the 1/2 doors ...
- Ring and Pinion Carnage
- Several Questions
- How I get 25MPG with my 3VZ-E
- My Winch Arrived!!!!
- losing coolant
- Some good news!!
- Rear Window Problem Help!!!!!
- Tranny Cooler: How Big?
- 22re head gasket. looking for a head. grrr
- made some progress on my toyota
- New gearing problems
- repairpal
- Yay or nay?
- 3.0 exahust question
- 22r to 22re
- Step 1: New Stereo
- Do Work Son.... (pictures inside)
- bumper hitch?
- need Help Just bought a 1995 tacoma 4x4
- 4" Skyjacker Lift
- HELP!!! Shackle Troubles
- Blocked off egr, now engine knocking!!
- air horns
- Alternator Wiring
- 87 Engine swap problems.
- 22r EFI conversion
- 255/85/16 Got 'Em and Other Work
- 94 Toyota Truck 3.0 Rebuild Trouble
- Engine rebuild?
- no codes to throw
- timing off 20 to 30 degrees
- Rear Main Seal
- Rear spool question?
- 22r/22re
- Toyota motor swap
- Could this cause an oil leak?
- 3VZ-E; sequential injection or not?
- dash/interior lights
- Leaking sunroof
- next 4runner
- Water in fuel like symptoms...
- Swapping a late model axle into a 1st gen
- waterlogged starter?
- 94 4runner front bumpers
- 3vze seafoam distribution?
- How To Judge Pitman Arm Condition????
- Engine Light, What does it mean?
- Ignition Buzzes When Keys Are OUT!
- burns oil, good compression
- gonna get my demello sliders soon!
- truck vibration at idle when braking
- 1st LIFT!!!! Need opinion & advice
- Getting somewhere!
- replaced TPS- excellent results
- Idling at 500 rpms... is this right
- Front Hub Removal to Replace Wheel Studs
- Graduation Presents!
- aftermarket temp gauge
- waterforGas?? is this crap??
- Buying a 91 extra cab 4x4, 3.0 5 spd.
- touching up chassis paint
- Help Lost All Power
- Burning Smell....
- 22R will not Time to spec.
- my new home made shifter boot.......
- well i got some work done today and i painted her!! 56k dont even try to open
- Got me some v6 calipers for a deal today
- 92 4 runner 3L V6
- Head gasket done, now dies on startup
- Fan clutch on a lot!..
- Your thoughts on this radiator?
- Bushwacker fender flares
- tires question
- Gun Rack for Pickups w/ Beer Windows?
- Head Gasket?
- ball joint spacers and cv joints
- Blew its top!
- 3-in. BL = 33x12.5's?
- protect rear w/o replacing bumper?
- EFI fuse blowing...fresh rebuild PLEASE HELP!
- Driveshaft Length Question...Urgent!
- Half doors complete!
- 33's & Speedometer..
- new, used transmission noise
- High Idle.....Help
- Downey Header And Exhaust Questions
- Clunking noise
- 1995 3VZE Wiring Harness
- 22re online parts
- 94 Heater core diagnosis....
- temporary rear brake hose
- Custom Rear panels, 87 4Runner
- charging ac?
- fabtech "universal" light bar??
- headers anyone??
- 3VZE Engine Harness Question
- Fan Blower Resistor
- IFS Axle to Hub Seals
- idling trouble -please help
- What I did this weekend...88 yota
- Mixture control continuously rich
- picture of my 86 4runner
- Removing oil pan?
- Well I did it myself
- Clutch engages and disengages at the bottom of the pedal
- I'm so frickin mad
- Positive Review: replacment coilovers
- lower control arm or frame damage?
- Truck won't start
- Need some help, replaced radiator.
- Another great deal!!
- Truck won't start. Real time help needed.
- 94' 22re too rich
- Bouncing Idle
- Intake mod ideas?
- BJ Spacer Install
- Head bolts?? Need To replace on a 22-re
- Thanks guys!
- Just set the valves again on the 22re.
- Just painted the yoter.
- Fuel injection year
- Shaky/Vibrating Brake Pedal?
- speedo gear
- How is 261c better than 268 cam
- Is this the rev limiter???
- Desperate
- I just got 25mpg
- 33x10.5's and metric tire Q's
- clicking from auto shifter when applying the brakes????????
- Engine misses below 3000 rpms
- Road noise....how to lesson it?
- WHat Gears Do I Have?
- 86-88 Track/Wheelbase Width?
- Tranny Swap: 89 into 87?
- Intake question
- 95 4 runner 3.0 dies at idle when hot
- rear bumper idea
- IFS Rotor Torque Specs
- knock sensor help
- Removing Body lift, Factory bolt length?
- What does a missfire at start up sound?
- OEM replacement parts?
- Spray in bedliner for whole truck!!!!!!!! Good or bad idea??
- 87 22r help. running rich
- Future Project idea, whats you input?
- My Weekend mods
- Body Lift recommendations
- Tires?
- Carpet color?
- starting issues
- CA Smog question
- 22RE Miss then dies
- Truck stalled out please help
- What's the name fo this hose?????
- 5 speed swap pedal set question
- trick to rubber shock boot?
- Questions:5 speed swap: 89 4urnner 3.0 Auto
- My 1989 2wd truck lifted
- trying again for replies: shaking truck!!
- Installing used 22RE this weekend....question tho???
- Failed state inspection on brakes
- Thank You Craigslist!!!
- '90 PU alternator
- Just got my new vinyl floor kit for my 86 4runner :D
- 89 toyota 4x4 xcab with 4runner engine
- looking for a tranny rebuild kit
- OIL leak suddenly got a lot worse
- tires?
- i drink from the keg of glory!!!!!!!!!!!
- another question, block markings
- new exhust, now code 21
- simple question, compression check
- Fuel Filter Woes
- Mini Tune-up (with pics)
- 1995 4runner front diff question
- It just died
- air horn ?
- I painted my 4runner yesterday.
- Newb needs some help! lack of power, 1995 V6 4Runner
- Tell me what you think
- Gasket Kit for 3VZE Valve Job?
- Tranny leak!(pic) 22re 5spd Help!
- My truck will not rev?!?!?
- Engine from new into old question
- this is what happens when you get old and bored
- auto tranny question
- Won't start again
- my rims your rims everyones rims
