How to change CV axles?
Old Jun 16, 2008 | 03:49 PM
THE_KID's Avatar
I just bought a 91 4runner and it came with 2 new cv axles. I want replace them with the old ones because there is a popping and grinding sound from the front when its in 4 wheel drive. how do i change the cv axles?
Old Jun 16, 2008 | 04:09 PM
Team420's Avatar
This should help
http://www.ncttora.com/fsm/1990-1995...l/frontaxl.pdf
Old Jun 16, 2008 | 04:15 PM
CJM's Avatar
CJM
Did you drive in 4wd on the pavement, it will pop and grind.
Old Jun 16, 2008 | 04:24 PM
THE_KID's Avatar
I was on hard dirt about to cross a pipeline trench that had a spot where dirt filled the trench so I could cross.
Old Jun 16, 2008 | 04:26 PM
CJM's Avatar
CJM
Then yes sounds like they are bad. Look at the boots on them and see if the grease is coming out-thats a big sign they are toast.
Old Jun 16, 2008 | 04:36 PM
THE_KID's Avatar
Yea there is a little bit of grease left in them. I want to just replace them since I have new ones but I just dont know how.
Old Jun 16, 2008 | 06:55 PM
bigt's Avatar
get 2 floor jacks
one goes under the opposite side rear axle of the cv you are changing.
one goes under the a arm the closest you can get it to the outside of the truck...
unbolt end of axle from hub..
unbolt 6 bolts on diff side of cv..
then you can wiggle slide it out.. i didnt need to undo anything eles and changed the cv in about an hour first time.. it was passenger side
Old Jun 17, 2008 | 02:38 AM
SwampThing's Avatar
How do you change CV angles? Cake, you just crank em torsion bars. You did say change em for worse right?
Old Jun 21, 2008 | 06:42 AM
THE_KID's Avatar
I need to change the axles not the angles.
Old Jun 21, 2008 | 07:05 AM
ozziesironmanoffroad's Avatar
when you're in 4x4, you hear a popping and a deep rumble that sounds like its coming from the front, huh? yeah, CV would be my guess. mine do the same thing, as soon as i get the money to replace em, i am. but how sure r u that your hubs are ok?
Old Jun 21, 2008 | 08:07 AM
Brenjen's Avatar
the bolt & the c-clip on the axle end (might not be a bolt,some don't have it) & the bolts around the axle flange (under the truck). The rest is holding your mouth right while you wiggle & cuss & try to line them up with the cut out's on the flange & wiggle some more.
Personally I just popped out the studs with a c-clamp & ground off the splines, now my cv replacement only takes a few minutes for both sides to be done; still a pita but not nearly as bad as before.
Old Jun 21, 2008 | 10:15 AM
THE_KID's Avatar
Yea the popping and rumbles comes from when I turn in 4x4. Sometimes it even pops and rumbles when the wheel is all the way to the right or left in 2 wheel drive. I have 2 new cv's to put in and I'm gonna give it a shot today hopefully.
Old Jun 23, 2008 | 08:02 PM
THE_KID's Avatar
I got the new axles in and it turns smooth in 2 and 4 wheel drive. Thank you guys for your help.
Flying91
45
Apr 11, 2024 04:39 PM
polo451
13
Nov 20, 2016 07:49 PM
jerusry
Oct 19, 2015 05:28 PM
deepmarsh
Aug 6, 2015 03:44 AM
Backcountry411
Jul 24, 2015 08:06 AM
