5 speed swap pedal set question
Old Jun 5, 2008 | 03:57 PM
Luvmeye22re's Avatar
I have an 86 4Runner 22re auto, and have a line on a trans. right now (as long as it doesn't sell before I can look at it on Saturday). Do I need to get a pedal set from an 86-89 4Runner/pickup or would anything from 84-95 work? I know for a fact the pedal sets for 79-83's were a lot different, at least the gas pedal. Also does it matter if it comes from a v6 truck? I'm sure I'll have questions before every part I purchase so I apologize in advance.
Old Jun 5, 2008 | 04:03 PM
DeathCougar's Avatar
84-89 4runner or 84-88 truck. The later model pedal assys wont bolt in
Old Jun 5, 2008 | 04:14 PM
Thank you
Old Jun 5, 2008 | 05:08 PM
SLOWBOOST's Avatar
the auto pedal assemblies actually have all the holes for the clutch pedal, so if your in a bind, you can cut the clutch pedal off any year and weld it back on to your setup, just switch out the brake pedals and your good to go.
Old Jun 5, 2008 | 05:13 PM
I've been quoted $25 at the local Toy yard so I think I'll just get the entire assembly but good info. I appreciate it.
Old Jun 6, 2008 | 04:37 PM
I'm also wondering.....I already have a slave and a master that were given to me and they came from a 94 pickup that had a w56 (Not sure if its an A etc.). Do I need to make sure the slave/master are matched to the transmission that I end up with?
Old Jun 7, 2008 | 04:14 AM
SLOWBOOST's Avatar
im almost positive they are all interchangeable. On my truck i have an 88 3.0 master and an 85 22r slave.
Old Jun 8, 2008 | 09:30 AM
Good to know. How about the crossmember, will I need to get one from a manual truck? I plan on going with one from Budbuilt eventually but for now it's going to be all stock parts going into this (aside from my Marlin clutch ).
Old Jun 8, 2008 | 11:00 AM
just a 22re's Avatar
not sure abou tthat i think that all the trasfercases are the same as far as bolting them under there but i think thats how it is
Old Jun 8, 2008 | 11:49 AM
auto and manual crossmembers are different
Old Jun 8, 2008 | 04:06 PM
SLOWBOOST's Avatar
i just confirmed it while cleaning out my garage, the crossmembers are different, but not by much.
Old Jun 9, 2008 | 01:10 PM
AndyL's Avatar
Crossmembers are Identical - however the mount is radically different. Did the manual to auto (reverse of yours) back in october, used the same crossmember - had to swap the mount though.
coryc85
Sep 9, 2015 06:24 AM
Cplmike
Jul 8, 2015 08:47 PM
karbin
Jul 5, 2015 11:37 PM
HRDC0R19
Jul 5, 2015 06:43 PM
