Engine misses below 3000 rpms
Old Jun 6, 2008 | 09:29 PM
neilo's Avatar
Whats up guy newbie here so take it easy on me. I am working on a 91 4 runner with the 3.0 engine and it misses until it gets up to about 3000 rpms. I did the plugs, wires, cap, and rotor. I have double and triple checked all that and gone over every inch of vacuum line that I can see and can't seem to find the problem. This is my first Toyota and I am a lot more accustomed to working on older carbureted stuff. I hope you guys can guide me a little here as it is getting to be a pain in the rear. It seems to run ok going down the highway but it doesnt want to lug at all and doesn't get the mileage that I thought it would. (Not sure what it should get though) It has a 5 speed transmission that I have some questions on but I will get to that in another thread. Any and all help is appreciated.
Old Jun 8, 2008 | 12:13 PM
neilo's Avatar
Just bumping this still trying to figure it out.
Old Jun 8, 2008 | 12:45 PM
TORTIS's Avatar
have you ohm the coil, and checked the tps?
Old Jun 8, 2008 | 05:56 PM
neilo's Avatar
I have tested the tps and it seems to be fine, how do you test the coil?
Old Jun 8, 2008 | 06:04 PM
abecedarian's Avatar
using an ohmmeter or multimeter, you check the resistance between the center connector and the + terminal, between the + and - terminals and between the terminals and case.
I don't have the specs in front of me so I can't say exactly what they are but they should be in the FSM manual linked from https://www.yotatech.com/forums/f116...umbers-102344/
smthwsn357
May 1, 2024 07:28 AM
icentropy
Sep 16, 2020 02:47 PM
akaphilly
Jul 9, 2015 02:34 PM
88runnergomas
Jul 9, 2015 01:12 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
