Rear spool question?
Old Jun 11, 2008 | 01:45 PM
ross p's Avatar
I have a 93 4x4 pickup w/22re 5 speed. i am currently running 33x13.5 ltb's and 5.29 gears and i drive about 10,000 miles per year. I dont have the money for a locker so would a spool be a good or bad idea?
Old Jun 11, 2008 | 02:05 PM
fillsrunner4's Avatar
Just weld it and save even more works great
Old Jun 11, 2008 | 02:07 PM
ross p's Avatar
I dont drive very much , but as much as i do drive im a little skittish about welding it up
Old Jun 11, 2008 | 02:09 PM
Same thing as a spool
Old Jun 11, 2008 | 03:42 PM
AxleIke's Avatar
If done right, a welded diff is no different than a spool. Much cheaper. Just weld it, but make sure the welds are good.
If you are on a budget, and are only driving 10k a year, a welded set up will serve you well.
Old Jun 11, 2008 | 03:56 PM
bigt's Avatar
yup the only road my trail rig sees is too and from the trail... its welded up and i love it!!
Old Jun 11, 2008 | 04:05 PM
Luvmeye22re's Avatar
Yes, make sure somebody competent welds it up, and make sure the machine is turned up nice and hot. Get the gears really really clean and spray anti-spatter anywhere you won't be welding to keep clean-up to a minimum, you don't want all those bb's stuck to your ring and pinion when you install it. I have heard of people using some 1/4 plate steel to help beef it up along with/over the first welds but I've never done it and it worked just fine.
Old Jun 11, 2008 | 05:08 PM
86blue4runner's Avatar
i wouldn't weld it. ive seen to much bad stuff happen, even when done correctly , and taking all precautions. This is my personal opinion, but if it were me, i would do it right the first time, and spool it, or save up and do a locker.
Old Jun 12, 2008 | 09:31 AM
run4her's Avatar
I burn through 2 sets of cooper stt's in one year and 15,000 miles with my spool.
the1998sr5
15
Jul 14, 2020 08:35 PM
rushw
Jul 18, 2015 01:46 PM
icentropy
Jul 14, 2015 10:23 AM
87turboPA
Jul 12, 2015 07:49 AM
87turboPA
Jul 9, 2015 05:58 AM
