Failed state inspection on brakes
Old Jun 5, 2008 | 07:29 AM
ahickman's Avatar
Went to pick up my 94 3.0 Runner from the state inspection station and found that it had failed owing to the front right and rear right brakes. No details were given so I drove it home and took off all wheels to expose the pads. Back shoes are new and front pads still have 1/4 inch. Bled the front brakes and started on the back. Took me a minute to figure out I had to have the rear ABS actuator charged up to allow fluid to pass back to the cylinders. After bleeing the brake lines (no air coming out, only fluid), I have have worse stopping power than before. Any tricks or suggestion on what to do next? There are no leaks at any of the calipers.
Old Jun 5, 2008 | 08:08 AM
dirtoyboy's Avatar
Sounds like you might have a bad master
Old Jun 5, 2008 | 08:46 AM
ahickman's Avatar
Is there an easy means of checking the master cylinder?
Old Jun 5, 2008 | 12:57 PM
just a 22re's Avatar
motor off pump the brakes a few times then with all your might jump on that pedal if she goes down with your body weight then you know theres something bad there
Old Jun 5, 2008 | 09:44 PM
thook's Avatar
First Aaron can't go....now, Aaron can't stop. Lol....crazy.
What Allan said.
Old Jun 9, 2008 | 04:16 PM
ahickman's Avatar
Matthew...I knew I could count on you!
Blamalam
Mar 12, 2022 07:34 AM
corey519
Aug 12, 2015 11:12 AM
romex1
Aug 10, 2015 06:21 PM
accuracy
Aug 4, 2015 08:05 PM
Jnkml
Jul 6, 2015 01:20 PM
