It just died
Old Jun 4, 2008 | 11:23 AM
manxbuggyman's Avatar
It just died
1993 truck v6 auto. Driving down the road and it died. Tried to restart and it just turns over.(no wiered noises) Checked for fuel by opening line and it was pressurized. Took off dizzy cap and turned the key and the rotor does not turn.....
The truck has about 480,000 miles on it and about 85,000 on the engine.
What is next???
Anyone know what to check for next? I am on the way back to Iowa to pick it up.
Dwight
Old Jun 4, 2008 | 11:30 AM
76ANTHONY's Avatar
What is next???
Dwight
timing belt most likely, tear it down...
Old Jun 4, 2008 | 11:34 AM
bigtrucknwheels's Avatar
timing is my guess as well. lucky for you, 3vze is a non interference motor, no damage, just temperary downtime.
Old Jun 4, 2008 | 11:40 AM
DeathCougar's Avatar
Same as dem guys say. Your timing belt is broken, or your cam has a problem. Tear it down and figure out whats going on.
Old Jun 4, 2008 | 11:42 AM
Thanks guys. I can do a timing belt without pulling the motor. I didn't know the dizzy was driven of the timing belt, but I will look there after I spend the next 6 hrs going to get it.
Old Jun 4, 2008 | 11:43 AM
where are you from?
Old Jun 4, 2008 | 11:50 AM
kansas city
Old Jun 4, 2008 | 11:55 AM
76ANTHONY's Avatar
timing belts pretty simple, takes about 2-3 hours if you do it correct. parts are cheap too....
Old Jun 4, 2008 | 12:09 PM
Thanks guys. Heading out to get it. Let you know how it goes.
Old Jun 4, 2008 | 12:11 PM
76ANTHONY's Avatar
id like ta see the pics when your done
Old Jun 5, 2008 | 04:12 PM
You guys were right... broken timing belt. I pulled the cover and it was torn and then broke.
It looks like I am going to have to remove the oil pump and harmonic ballancer as well. Is there gasket for the pump or do I use Toyota gray rtv?
Old Jun 5, 2008 | 04:21 PM
Why would you have to remove the oil pump? Was it damaged?
Old Jun 5, 2008 | 04:29 PM
just a 22re's Avatar
yeah it should just be the crank pulley and the cover then the adjuster and you should be all ready for the new belt i thinky
Old Jun 5, 2008 | 04:44 PM
pat24's Avatar
oil pump ??? its a water pump if you do a timing belt do i water pump the first one i did i didn't and it ran great than the pump went and tore the new belt apart so don't forget
Old Jun 6, 2008 | 02:45 AM
Sorry.... I ment the water pump.Oil pump slides over the crank. I only have about 80,000 miles on the water pump but they are cheap and I don't want to do this again soon.
Old Jun 6, 2008 | 08:40 AM
76ANTHONY's Avatar
always replace the waterpump when you do a timing belt
and they come with a gasket also....
glad ta hear your gettin it done
Old Jun 6, 2008 | 02:38 PM
It is done and running again. Things to remember for the next time...
1. You don't have to remove any of the accesories, ie alt, power steering pump or ac.
2. After you line up all the marks and install the belt don't expect the lines on the marks after you turn the motor.
3. Put sealer on top radiator hose around the studs as well. One of them goes into the water kneck.
4. Back fill the block with antifreeze thru top radiator hose.
5. Put on all new belts.
6. Remove spark plugs before starting the belt install. Makes it much easier to turn the motor over by hand.
This has been a fairly easy job. One that most people can do with minimal skills.
Thanks guys for all yous assistance.
Dwight
Old Jun 6, 2008 | 02:52 PM
76ANTHONY's Avatar
Dwight
awesome, glad that fixed it, now you got another 60000 miles to go on that belt....
Steven.m.paulk
Jun 7, 2020 10:45 AM
shisha1999
Mar 3, 2016 07:09 PM
Chicken12
Oct 14, 2015 03:54 PM
Rcbc92
Sep 26, 2015 03:00 PM
