PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 [122] 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. 92 3.slo to a 96 3.4 motor swap
  2. A few questions... Timing & Cold Idle Kick Down.
  3. Power Steering leak; 92 pickup SR5 V6
  4. totalled or still worth fixing?!?!?!?
  5. Heater Hose Hardline Help
  6. New Owner of 95 4Runner
  7. 88 4runner fuel pressure problem
  8. Wheel bearing/CV joint question.
  9. anybody rebuild a CT-20?
  10. Help me! Tranny fluid change.
  11. headgasket gone!!!!!!!!
  12. 87 4runner 22re - very low power
  13. cam identification?
  14. Problem with 4x4
  15. No spark 91 4Runner 3.0
  16. CV Boot and axel
  17. 3.0 Engine Valves/Exhaust
  18. heating problem - 89 4runner
  19. 88 4runner front main seal leak
  20. will not idle just dies
  21. code 25
  22. Temperature gauge running too cold?
  23. installing headers soon
  24. Removed ABS sensor, now check engine light?
  25. '91 3VZ - Identify my hole :)
  26. Upgrades for stock height suspension?
  27. 3vze removal..big pain in the A!
  28. 22R Swap - Trying to Get Going
  29. Trying to get the heat working again.
  30. 22re help....
  31. What is this wire?
  32. 1st gen 4runner cargo panels
  33. 2nd gen 4Runner rear quarter panel hack
  34. r150f rebuild?
  35. 1987 4Runner Intermittent Starting Problems
  36. Ugh heater core pipe help a NEWB out
  37. Need info on broken 22re parts
  38. Front wiper fluid stopped
  39. Zuk Mod options and opinions with pics
  40. 22re head gasket brand
  41. 3.0 Engine Grounds
  42. RUST, need some advice
  43. 95 3.0 gas/exhaust smell
  44. Vanishing coolant
  45. bogging down
  46. 22re cam/crank timing off... i think?
  47. Replaced Headgasket on my 87 4runner 22re, and now smokes
  48. 3.0 head bolts
  49. Engine stalling while wheeling
  50. Info Please! replacing solenoid on A340H transmission
  51. NO Compression.....NONE!
  52. Help!!! I just screwed...well broken bolted myself
  53. Winter Issues
  54. CV joint shaft differences?
  55. Water pump bolts tricky to remove
  56. help to pass CA smog high hc 3vze
  57. another 3.0 no spark
  58. NA and Turbo questions
  59. New 22RE Performance Engine Install
  60. Milky white oil cap -.-
  61. 4 runner pulsing when brakes applied
  62. 87 22re Just Dies
  63. Trying to get Power Steering pump out of 3.0 engine bay - having issues
  64. Re-Keying door locks?
  65. rpms
  66. Clicking noise on cold startup
  67. Starter issue - no clicking tho
  68. 86 4runner Air Intake Build (pics)
  69. 22re Dies at Idle When Warm, EFI relay clicks
  70. 3.4 convertion. need hood scoop, HELP!!!!!
  71. battery draining
  72. transfer case fill plug
  73. why did my coil wire melt
  74. 3.0 rear cam seals
  75. 2Dr. 2nd gen runner door question
  76. Pulling a camping trailer with 95 4Runner
  77. Question about seats.
  78. AT Transmission fried, now what?
  79. Idler Arm Bushings?
  80. 1986 4x4 whining...........help!!!
  81. Aftermarket fj80 coils in 2nd gen 4runner.
  82. E-Locker/3rd Member/Axle Confusion Questions
  83. How fast can I go in 4x4 (1989, 22RE, auto)
  84. Clutch pedal sticking near floor after shifting in '95 4Runner
  85. Air in system after new water pump?
  86. Power Steering Leak
  87. 1987 4Runner Engine quits pulling at like 3000 rpm!
  88. anti freeze
  89. Pair Valve Cleaning, can it be done?
  90. Newbie post, 89 4-runner, where is the fuel filter??
  91. What did I Do?! (seafoam content)
  92. clips for lights. grill.
  93. Vibration when in 4WD
  94. A few questions as I replace my W56 trans
  95. OME D6XL Extra Leaf in 1st gen 4runner?
  96. Camry Alternator 3VZ Swap
  97. CV axel/boot options
  98. Extended cab doors on reg cab?
  99. Knocking but not bent valves
  100. guess what the dealership wanted $54 for...
  101. Which pulley is it?
  102. Transmission Removal
  103. Fuel pump wiring
  104. 3.5" flexible intake hose
  105. Engnbldr rebuild and cam
  106. Another 22re missing thread
  107. Body Panel compatibility pickup-4runner
  108. 93 pickup won't start, but pushstart works
  109. 22re Fan Clutch Question
  110. 1988 Toyota Pickup 4X4 starting trouble
  111. Ecu help on 1988 4runner 22re
  112. 1985 4runner ebrake suggestion ?
  113. Dashpad repair
  114. Websites with diagrams?
  115. Alternator vs battery question
  116. My new rig - 2nd Gen 4runn (and the problems it came with)
  117. Trouble Codes Help
  118. What do you make of this?
  119. '86 runner dies after 2 min, wont restart
  120. clutch pedal adjustment
  121. aluminum clamps for 4runner top
  122. New Toy! 91 4runner build (or rebuild)
  123. 95 3.0 exhaust (muffler question)
  124. No power after doing timing
  125. Misfire : 3VZ
  126. Ideas on electric fan?
  127. 120v On Board Air using an inverter
  128. General Question regarding my Cheapishness
  129. Damaged Distributor Pickup Coil and Sprocket
  130. headlight swap
  131. I've been running on a bad AFM?
  132. erratic idel
  133. 1991 toyota 4runner 4x4 3vze sr5 rough idle
  134. 22re rough idle
  135. Zuk mod question spring rates
  136. catylitic converter
  137. wiring question, parking lights,dash lights
  138. 22re-changed fuel line now wont start
  139. 1993 3vze clutch job. (bakersfield)
  140. Zuk Mod Installed With Discovery Coils
  141. 1991 3vze pickup help with smog
  142. Have to rev engine to get trans to shift
  143. Another 3vze Rough Idle issue
  144. A simple brake job turned into a headache
  145. Blower fan switch
  146. Clutch Not Fully Disengaging
  147. My 94 tr4 Transmission
  148. uncoding the differential
  149. 91 r150 speedo problems
  150. DIY rod bearing service
  151. 92 toyota 4runner
  152. 1st gen runner seatbelt retractors
  153. when i disconect the pcv it dies ? why
  154. Cracked Block or Casting Flaw???????
  155. Tuffy Series II Security Console 6.5" in a 1st gen?
  156. REBUILT 3vze surges when acclerating....hellpp
  157. Seat Belt Warranty
  158. Emissions Equipment questions.
  159. Where do ground wires typically go?
  160. Where do these hoses go?
  161. rebuilt 3vze surges once it reaches 1700 rpm
  162. Differences between 85 and 87 22re?
  163. Brake Bleed Mystery!
  164. Fuse for EFI blows
  165. Replacement seats for taller people?
  166. smog legal aftermarket carb?
  167. Boost problems
  168. buzzing noise when driving
  169. Tranny Problem
  170. Ring and pinion help
  171. no lights when key is on???
  172. Dreaded CEL code 71
  173. codes 11 and 12
  174. engine ran good before swap, now rich?
  175. 2nd Gen Rear Deflector measurements
  176. IFS front diff cv studs
  177. Rim caps
  178. Overheating Problem
  179. Trottle body question
  180. after head gasket job, timing belt off 1/2 tooth
  181. 285s on a stock pickup
  182. Crank Removal
  183. new slave, cannot shift out of neutral!
  184. Chevy axle swap questions
  185. 3VZE timing Belt Question
  186. 92 4runner starter problem
  187. Fuel system losing pressure
  188. 86 pickup hesitation
  189. 2wd tranny install.
  190. replacing the factory front crossmember
  191. Best thermostat temp for 22re
  192. Shifter Linkage/Cable Adjustment
  193. O sensor 89/22re/4wd
  194. info on exhaust systems
  195. Yukon Grizzly Locker for 95 Runner!
  196. What could be wrong with my front axle (not locking in)
  197. Burned Exhaust Valve. Fix the one bad valve or buy new head from engnbldr?
  198. 92 4Runner Door Locks Wiring Diagram?
  199. Addicted off Road bumper is on!
  200. Seat repair
  201. 95 4runner 3.0 barely made it home !
  202. 2 gen charging issue
  203. Engine builder 268 eBay cam?
  204. Head gasket or not?
  205. sensor that I cant seem to match up with my 89 harness
  206. SR5 center console...
  207. 93 4 runner strange grinding noise from left front after wheeling
  208. 1JZ AT swap
  209. 3.0 teardown for head gasket swap ques...
  210. 3.0L V6 North west offroad header install
  211. Vibration Woes.
  212. 3.0 ISR mod...94 4Runner
  213. A43d tranny dipstick on different side question?
  214. Choosing the right headgasket set
  215. Over heating!!!! Need some Perspecitive
  216. Post your best road trip with your 22re! (Pics welcome)
  217. check engine light one quick flash, same time rpm's drop.
  218. Cat off exhaust questions?
  219. NEW 88 22re rebuild, lots of oil from exaust
  220. 3rd member help
  221. Still runs bad when warmed up
  222. Autozone idler arm + SDORI bushing still the best route?
  223. 22re- Idle is running up and down
  224. removed my brake sensor
  225. Seat question
  226. Injector cutoff when braking and sudden jerking
  227. How to remove old shackles w/bushings
  228. header problems 22re
  229. knock coming from air box
  230. 1991 sr5 4runner Brake trouble.
  231. 87 22re Alternator Bracket placement?
  232. No start, need help asap.
  233. time for new suspension
  234. Help...drive line needed 1988 4 runner
  235. Exhaust Replacement on 87 4Runner
  236. Another belt question
  237. ignition timing
  238. 93 4runner muffler and tailpipe replacement.
  239. 93 4runner radiator replacement
  240. Need help with an odd 3.0 problem
  241. drive shaft stay 2 piece or go long?
  242. 86 toyota 22re,5 speed with a roar
  243. need some input
  244. engaging choke? 22r
  245. Removed both sway bars !
  246. Sonuva... Oil/Engine Trouble in Seattle
  247. Which h pipe goes to the power steering??
  248. AFM repairable?
  249. dual rear axle 4x4?
  250. 3vze Hose Connections
