Water pump bolts tricky to remove
Old Nov 13, 2010 | 12:59 AM
mapple83's Avatar
94 4x4 pu 22re w/ ac; i'm in the midst of replacing the water pump at the stage of removal of the water pump mounting bolts going by my chilton's repair manual. the manual says to remove the water pump mounting bolts while the fan assembly is still on, but this creates a problem because the clutch won't allow me enough room to fully unscrew the bolts. is there a trick to this or is the book just dumb and i have to take the fan and clutch off the water pump first. wouldn't be surprised if the book is dumb...if it's me, lets just still blame the book
Old Nov 13, 2010 | 01:25 AM
toyotabull's Avatar
the chilton's manuals seem to lack common sence sometimes, but pull the 4 nuts or bolts holding the clutch to the pump, and slide the fan out the way. Then you can get to the pump bolts easier. And yes the book is dumb
Old Nov 13, 2010 | 01:46 AM
mapple83's Avatar
haha thanks t-bull! i thought so. i just needed the reassurance.
Old Nov 13, 2010 | 04:16 AM
waskillywabbit's Avatar
Throw away that pile of crap manual
www.ncttora.com/fsm
:wabbit2:
Old Nov 13, 2010 | 04:22 AM
xxxtreme22r's Avatar
^^^^ Glad he said it, x2
Old Nov 14, 2010 | 12:28 AM
mapple83's Avatar
www.ncttora.com/fsm
:wabbit2:
haha yeah i've almost set it on fire a few times, but it's all i got and spending $150 on a book isn't in my budget at the moment. i'm sure i'll end up pulling my hair out soon and ordering one though. are they bone head friendly? (i mean pics and stuff)
Old Nov 14, 2010 | 05:07 AM
Did you even look at the link above?
:wabbit2:
Old Nov 16, 2010 | 12:13 PM
mapple83's Avatar
:wabbit2:
just did. why is the 94 truck allways missing?
Old Nov 16, 2010 | 12:20 PM
mapple83's Avatar
Originally Posted by razed
it does say to loosen the alternator (that shares the belt with the water pump) and remove the radiator shroud and drain and remove the radiator, right? good advice.
then you loosen the bolts a few turns each bolt until you can pop the water pump off with the fan attached
that's worked for me a few times and no need for the fsm.
yeah i thought about doin that but it seemed like a pia especially when i was gonna have to take the fan off to put in on the new pump anyway.
Old Nov 16, 2010 | 12:32 PM
Any year/model close will work. Same 22RE engine.
:wabbit2:
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
TammyMarie
Jul 15, 2015 11:14 AM
Jonny246
Jul 12, 2015 04:51 AM
cars-guy
Jul 11, 2015 07:51 PM
