RUST, need some advice
Old Nov 14, 2010 | 08:05 AM
89YOTAA's Avatar
New to the forums. hows it goin.
I recently purchaced a 89 toyota pickup. 22 re, lifted etc. after having the truck home for a week i noticed a spot on the inside of the frame. kinda looked like it split at one point and now has rusted out. it located on the passenger side rail, right beside the gas tank. after some research i have found out this is a very common place for these trucks to rot. so i plan on pullin the gas tank and box to fix it. anybody else done this? what is involved? etc
thanks
Old Nov 14, 2010 | 08:31 AM
Teuf's Avatar
When you pull the gas tank, be careful of the fuel lines. You will need to pull the fuel pump to drop the tank.
Old Nov 14, 2010 | 09:55 AM
beantickler's Avatar
Do yourself a favor and buy new guts for the tank... I bought all mine from ebay on the cheap. I had the same hole. I took the bed off and gas tank out and welded a box around the frame... Also be carefull removing brake lines from the frame rail cause they will be a coroded mess and brittle...
It's really an easy fix. Good luck!
Old Nov 14, 2010 | 10:07 AM
89YOTAA's Avatar
yeah i got a wicked deal on a brand new tank so ill prob use that
Old Nov 14, 2010 | 10:23 AM
waskillywabbit's Avatar
1982 pickup thread of mine has pics
:wabbit2:
Old Nov 14, 2010 | 12:26 PM
blueyoda's Avatar
POR-15 (or DOM-16 in canada) USE IT!
Old Nov 14, 2010 | 01:10 PM
Teuf's Avatar
In rust belts Por 15 is OK for the outside, but for the inside out, mmmmm.
Old Nov 18, 2010 | 07:08 PM
4SeasonHarvest's Avatar
89' 4x4 with severe frame frust where leaf spring attaches
Hey everyone thanks for info so far. This is my first post.
I recently bought my 89' 4x4 pickup and soon discovered rust and frame deterioration where the leaf spring attaches on the passenger side. It has become worse and needs remedied asap.
Does anyone know if there are any links on how to drop the gas tank and take off the bed?
Once I get to the rust spot I'm going to weld a sleeve around the frame.
89Yotta how did the fix go?
Old Jan 3, 2012 | 08:48 AM
Teuf's Avatar
Welcome 4Season. That would be hard to explain, try the FSM. Google (yotatech fsm download), good luck.
Old Jan 3, 2012 | 05:56 PM
sided00r's Avatar
I used this link http://img.toyotanation.com/forum/80...ml#post3100004 to take off the bed, it's not hard even i managed, and with the bed off it's so much better to see and assess all the undercarriage. The tank too is just a handful of bolts but on my truck there was one very problematic fuel line where it is stuck to a bit bolt, wound up with a kink and a pinhole had to cut out. Here's a link in case your bracket is salvageable. http://forums.exploringnh.com/showthread.php?t=6779 and here's a link in case rust welded your bolts http://web.dimebank.com/tech/BrokenBolt.html - i have a ornery catalytic removal challenge if you want any practice with rustwelded bolts. Had a dream. nightmare? someone told me it could take all day to drill through one rusted bolt. Haven't tackled it yet, but got through a different small one good enough the other day.
I made sure everything got lots of PB Blaster well in advance of the wrenches. Now the bolts are all soaking in molasses to see if that stuff works like the aussies say.
Old Jan 5, 2012 | 09:49 PM
streetlancer's Avatar
^ what was that about??? Yup, i remember reading a thread about sequoias and their frames rusting....
icentropy
Sep 16, 2020 02:47 PM
boguspiano
Dec 17, 2015 02:51 AM
Iceman4193
Aug 28, 2015 08:43 PM
matrad
Aug 8, 2015 03:00 PM
MTLroadierunner
Jul 20, 2015 03:07 PM
