2 gen charging issue
Old Nov 2, 2010 | 06:27 PM
charley1972's Avatar
My 91 4runner is having issues charging. It will start fine, just will not charge more than about 12V. I pulled the alternator and had it tested it was fine. I have changed the battery terminals, new ground straps, still not charging corectly Any ideas
Old Nov 2, 2010 | 09:28 PM
scyotapu's Avatar
voltage regulator could be bad. have you swapped a diff alternator into it just to make sure yours isnt bad?
Old Nov 3, 2010 | 10:23 AM
I will hook it all up to voltage meter and an amp meter to see what its doing. I kinda figured it was the regulator, but it cant be changed separate from the alt.
Old Nov 3, 2010 | 11:17 AM
Hilux808's Avatar
Most likely sounds like your alternator has issues but doing a few other checks doesn't hurt. Do a voltage drop test on the positive side of the alternator circuit, while the truck is idling measure the voltage from the output post on the back of the alternator and the positive battery terminal. If you get higher then 0.20 volts then something is wrong. Make sure all connections are clean.
Read this article on alternators and testing...
http://www.aa1car.com/library/charging_checks.htm
80Truck
Oct 12, 2025 07:25 PM
rondogracing
Engine Swaps
16
Aug 24, 2015 03:02 AM
noahstancik
Jul 17, 2015 05:38 PM
tpd143
Jul 7, 2015 09:06 AM
coryc85
Jul 6, 2015 04:07 AM
