285s on a stock pickup
Old Nov 3, 2010 | 07:41 PM
Rerunn's Avatar
Ya'll think 285/75/16s would fit on my stock reg cab? just curious got some 16 inchers for cheap and im shoppin for tires. If not i'll just go with 265/75/16s
Old Nov 4, 2010 | 02:22 PM
Rerunn's Avatar
They are about the same as 33/10.50s so a little pinch weld beating possibly and they'll be ok i think. anybody elses 2cents?
Old Nov 4, 2010 | 05:01 PM
muddpigg's Avatar
Without gears it will be slower. This is one of those topics that comes up frequently. My truck had 33/12.5 on it when I got it. But not all tires are true size, so one brand may fit better. Check the manufacture specs for the true OD. You can always crank the torsion bars and put an AAL in the rear.
Old Nov 5, 2010 | 02:43 PM
Rerunn's Avatar
Yeah that is true and I plan on regearing shortly after. I was just curious as to what i could get away with without lifting. i dont wheel really hard so im not superworried about scrubbing
Old Nov 5, 2010 | 02:48 PM
4banginRunner's Avatar
*edit
285s will fit
they are only 33s, at most you'll have rubbing on the pinch weld at full lock/compression
Thats why we have sawzalls/grinders/torch/BFH
Old Nov 5, 2010 | 04:08 PM
bobby_duce's Avatar
to stay on the safe side id go with a 1" bodylift just for a little extra clearance too.
post some pictures once you get them on too!
Old Nov 5, 2010 | 04:11 PM
REDYOTA's Avatar
also depends on the wheel offset/backspace
Old Nov 6, 2010 | 03:54 AM
xXbrutalXcoreXx's Avatar
Here is my truck with 1.5" BJ spacers and a 1" BL on 285/75/16's. My rims are also 16x10 with 4.5" backspacing. Even with 2.5 inches of lift i still had to cut back some of the pinch weld to avoid rubbing while the steering was locked. Hope this helps.
Old Nov 6, 2010 | 07:43 AM
Back in the day with 295s (34s) with BJ spacers
*Edit
here's 265s stock height (with sagged springs)
Old Nov 6, 2010 | 08:03 AM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
I hate the metric system
I mean, it'd be different if we used the thing... Then I'd say that about ppl posting standard stuff...
285 x .75 x 2 / 25.4 + rim diameter (16) = 32.8" outer diameter tire.
Old Nov 6, 2010 | 08:20 AM
yotarob2005's Avatar
You are not the only one who hates that system, but thanks for that formula, I'll save it for future use.
Old Nov 6, 2010 | 11:22 AM
muddpigg's Avatar
Keep in mind that regard less what the sidewall says the OD of a tire varies by manufacture and even from tire design with in the same manufacture. I've read articles why some do this but really not going into that. The only reason I think it even matters here is a difference of 0.5" on stock truck with no lift will be the lots of rubbing vrs no rubbing. Just check the manufacture specs as it is always listed.
kazuya2416
Apr 5, 2024 02:17 AM
lledwod
Aug 30, 2016 01:03 PM
Sep 4, 2015 09:27 AM
garagespace
Jul 9, 2015 08:37 AM
Nickdigg
Jul 7, 2015 06:04 AM
