- front nightshot of my runner
- steering shaft recall
- How's my Mileage?
- low idle on startup
- tips for leaveing truck parked for a month
- What is this valve called?
- Problem with wheel bearings/hubs?
- who has had stolen 1st gen?
- strange groaning and such..
- Found culprit of mystery noise..how do I fix it?
- 89 PU - What fuel lines go where?
- Blown Cat. Converter.. Now what?
- Rubbing noise and i am scared
- 3.0 question
- 85' 4runner trans swap from 86-87 turbo?
- engine choices
- 87' 22re and 89' 22re ecu compatability
- Wonky key issues.
- 2nd gen automatic dual transfer case option
- Custom fabbed 2nd Gen valance
- Oil Leak on a 1995 4runner
- OK just did Ball joints and outer tie rods 2nd gen
- Head bolts?
- Some pics of my truck
- 2Door 2nd Gen vs 4Door lift comparison.
- 84 - 88 truck cab VIN locations
- Its cold out and my car will not start. Help!!!
- using the clutch start cancel switch as a kill switch
- I NEED exhaust specs! Please help!
- Body mods opinions needed
- Brake Failure
- 3.0l V6 help
- Ball Joints??
- At what temp will coolant boil?
- trans dapt info
- Heater Blowing COLD
- Manual Door Lock Problem
- Moding older 4Runner. Any help is great!
- I need a passenger side slider for 89 4runner
- Profit from my mistake... Search friendly 3VZ-E Timing belt tip !
- Please Help: Charging Problems
- My new Downey Headers
- I smell gas... why?
- Toyota Diesel Conversion FAQ and Guide
- yea i need some help
- 22re parts for sale
- L50 vs W56 transmissions
- Heat sucks in my 86 toyota...please help BRRRRRRRRRRR!!
- Rear driveshaft removal
- change 1st gen rear window trim
- 2 Gen 4 Runners w/column shifters?
- Starting issue.. help please!
- what other bucket seats will fit
- Part identification -- intake boot?
- Hmmm...seems TPS does affect MPG on 3VZE
- Help with 22re - running really rough
- I would like to introduce myself and ask a question--brake related
- 2nd gen cranks but won't start and no codes
- I finally did it! (Pics)
- Fluctuating Idle??
- 5speed pops out of gear HELP
- 2nd gen timing ticking
- no 4-wheel drive
- The timing on my 22-RE will not go to 5 degrees.... help please
- Squealing noise from tranny area?
- test drive
- cv joints possibly?
- pictures of 2nd gens
- a 340h transmission solenoids repaired!!!
- nevermind the 4wd oddity, now ive got a real problem...
- New pads and shoes on a 2nd Gen. runner
- Need new v6 for 91 4runner any suggestions?
- A/T OIL TEMP (Light) came on
- boiling over
- Will this fit in my 91 toyota reg cab?
- Clutch slipping!!!
- a couple of things...new cluth and some rear coils for my '95
- 1995 Toyota 4runner.. need opinions
- Desperate for 4wd Help!
- What's a code 11 for an '87 22-RE?
- Retorque your headers bolts!!!
- 91 4Runner 22RE Starts but wont stay running.
- 3.0 running like s@*t
- Very hard shifting when cold?
- 22re clatter opinions
- 93 22RE Truck will not start
- who makes the best head gasket? 22r
- 300,000 miles On 4cyl
- 4Crawler's Wiring Harness Mini Review
- vacuum lines
- I finally got a digital cam...pics of my runner
- Finally Got some pics of my rig!
- In the mail today: RECALL
- 2nd Gen 3.0 V6 upgrades
- 87 4runner -parts diagram
- 4WD (Four wheel drive) not working
- Free wheeling fan
- injector wiring 1988 22re
- Annoying Rattle on 93 P/U
- No Brake Lights!!
- Problem - 95 P/U with 3.0
- manual tranny fill plug...
- coolant smell and heater core repair
- Later 2nd gen headlights
- 3.0 to 3.4 swap in Boise, ID
- TRE (Tie rod ends) Woes
- I need ideas-93 4r auto V6
- 3.0 Head Gaskets, $2,710.26!!!
- 93 4Runner Power Steering Pump and Water Pump/Thermostat Replacement
- Anyone Running Light Force 240's on stock Bumper (2nd gen 4Runner) ?
- Engine is shot
- Where to buy a 22re shortblock?
- 22re head shim
- testing compression
- Can you clean the VAF
- Newbie - 93 4RUNNER- lift, maintenance and gas mileage questions
- bottom end work maybe
- 22RE Oil Pan Bolt Size (Drain Plug)
- Recall notice
- Blue smoke when letting off the gas(22rte auto)
- What was that recall on 2nd gen OD?
- Thread Pitch Question
- Power steering whine Please help!!
- Rebuilding a siezed engine.
- Is my alternator going bad?
- 94 4wd sr5 buckets fit a 2wd 91?
- 22re Exhaust flang gasket problem.
- Starter Issue
- Fluid spitting from exhaust
- Engine bogs down after driving through water
- slight hesitation when accelerating
- puff of blue smoke on startup?!
- remanufactured 3.0L recommendations
- my 3.slow rebuild
- 22re W/ Stock Gearing On 35's ????
- V6 3.0L Water pump Removal
- Problems w/ a 86 4Runner I looked at today
- Brakes sticking?
- I'm about to shoot my 2nd gear...
- Should the cold start injector timer be activated immediately after the engine starts
- Should the engine stall out when the idle adjustment screw is completely closed?
- Rock Bumpers
- squealing sound some where
- Brake pads uneven after bad caliper
- Weird tranny sounds
- How can I tell if the EGR valve is stuck open?
- sluggish accelerating pinging etc. since new engine
- Help me check my tranny fluid!
- EGR info needed.
- 4th Starter! Just "CLICK"
- Clutch release slave cylinder
- Car running bad when cold. Why?
- overheating question
- Ignition Issue
- 21mpg normal for 2wd 91 toy truck?
- Misaligned Door / poor seal to body
- blown head gasket!
- 2nd Gen: 3.0/auto vs. 22re/5-speed
- Installing a Tachometer on 94 Pickup
- Help Needed Urgently - Clutch release bearing
- asian hubs. greaseing question?
- xB kill....
- Infamous 3.0 Head gasket problem, Any Ideas?
- 4-Runner Rear Window INOP!
- CEL: Code 32 Air Flow Sensor and 52 is Knock Sensor
- Rough Idle
- Removing ADD
- idle problems and cylinder misfire Plz Help!
- Need pics of IFS With RANCO LIFT
- brake bleed
- Aligned my own truck, great results.
- sporatic missfire
- high idle and sterring pump nosie
- A few questions about my 90 4wd 3.0L
- engine runs rough in 4th and 5th
- Oil Pan Leak Question
- Bearing preload
- 94 4runner transfer case replacement cost
- Too much lift?
- fast clicking sound in a 1988 v6 4runner
- 1986 p/u igniter/ignition coil?
- 22RE Cold Start Injector Timing Switch Bypass?
- starting trouble 88 4 runner
- disable steering lock in a first gen?
- Idle problems
- Any one ever get a 7m AFM to work on a 3.0
- tighten mirror bolts?
- transfer case oil capacity
- Frame separation at front diff? Spec Needed!
- 3.0 Coolant bypass hose rear intake
- 3.0 to 22r swap?
- How to drop oil pan on 92' 4runner?
- CAM TORQUE SPECS 3Vze
- Does your 2nd gen. auto transmission please you?
- 1988 V6 auto having a hard time getting into OD! HELP!
- MAF Conversion Mod 3.0 2nd gen
- Can an a340h tranny from a 3.0 V6 fit on a 22RE 4cyl. engine?
- 1994 3.0 v6 (3fz-e) idler pulley questions
- A340H help
- oil pump replacement...
- Lose Ground wire question?
- Logging Gas Info
- Tuck moans when cold out??
- How do I get the rear power window motor out?
- Gearing auto v6 4.10-4.30
- overheating "HELP"
- How much should I be expected to pay for 22RE engine rebuild?
- adjustable throttle air by-pass screw??
- 22re timing chain/set timing/rtv/headremoval
- surging idle with a/c on?
- master cylinders
- broken torque converter bolt
- Prestone flushing kit 2.4l
- 40" tires on 2nd gen!
- Missing throttle cable brackets
- Rear Window****
- 2nd gen squealing belt
- 4Wheel Drive Wont Engage
- Does Low Compression means it needs a Valve job???
- Starter removal problems
- 22RE - Low compression? Issues?
- Replacing Valve
- Special Service Campaign for 90-95 4Runners, 89-95 Trucks and 93-98 T100s
- no more rear brakes?!
- Spark plug gap
- Overheating coolant problem '88 4runner
- Valve compression?
- wanna run 33X12.5 BGF Muds on my '95 4runner.
- growling noise
- voltage at starter control wire, but click, click.
- Rapid decrease in speed when letting off gas pedal?
- Hard shifting into 2nd gear?
- Allied Engines - Heard of them?
- Engine trouble...TPS throttle position sensor?
- Passenger seat bunged up
- rich fuel mixture
- No Power
- Problem with 22re
- radiator overheating problem
- tourqe specs for head bolts?
- Radiator leak or condensation?
- full top end & head gasket repair gone wrong?
- Fix Broken Rear Motor Window?
- New fuel filter made a difference in acceleration and smoothness
- Brake caliper problem
- Tranny Problem
- Toyota Knock Sensor needed????
- Heater core hose (best answer)
- Body stripe glue removing?
- Bought used '94 4Runner. Have questions now.
