cv joints possibly?
Old Dec 2, 2005 | 10:55 PM
andre16's Avatar
cv joints possibly?
I have a 91 toyota 4x4 with a 22re. I'm getting a loud noise from the front left wheel at 60 kilometers an hour and above. the noise goes away if i hit the brakes and slow to 50 ish, if i just coast the noise doesn't go away until a much lower speed, turning and bumps in the road also make the noise go away. I'm thinking its a cv as a wheel bearing would be always loud
Any ideas??
Old Dec 2, 2005 | 11:16 PM
Cedarbarn's Avatar
Solid Axle Swap!!!
Old Dec 3, 2005 | 12:04 AM
Bob_98SR5's Avatar
coast in circles in a parking lot. does it make a clicking sound? and is there grease everywhere because theres a tear on the cv boot?
if yes to the clicking, yes, its the cv. if grease everywhere, OH YEAH, its the cv
search "cv joint", "cv joint replacement", "replacing cv joint", etc for some answers.
bob
Old Dec 3, 2005 | 05:32 PM
eric-the-red's Avatar
And if you really want to know for sure remove the front axle shafts and go for a drive. If the noise has gone then it was the CV, if it's still there it could be wheel bearings or spindle bushings.
Old Dec 19, 2005 | 06:58 PM
t100's Avatar
i had the same problems for a while, i looked under my truck and found 2 torn cv boots... 500 dollars to get new boots and axles along with labor...
Old Dec 20, 2005 | 07:21 AM
shmily524's Avatar
Yes, it is probably your CV Axles. Take a good look and see if there are any cracks in the boots.
If so, you need to replace the axle. I just finished doing this last weekend. The axles were $80 per side.
It was a relatively easy job, and I put new bearings in while I had everything apart.
Old Dec 20, 2005 | 07:57 AM
ASU4runner's Avatar
I have a broken cv right now.. not even a month after I replaced the other side, this one went out on me. I bought the first cv from advance auto parts for $89 w/ liftetime warranty and went back the other day to buy the other one. Apparently the company that rebuilds the axles (for advance, autozone, etc.) went bankrupt and he said it could take 2 weeks or more to get ahold of one. I know I could buy a new one from the dealership, but I don't have the $$ to do that so I guess I'll keep looking around. Anyone have any ideas of places that might carry them for under $100??
Old Jan 1, 2006 | 11:47 PM
photoleif's Avatar
yikes! glad i got mine before they ran out (?). i went to advance for both of mine. you oughta be able to get reman *some*where for under $100. advance after the core return was $67. another place locally here wanted $80-something.
aowRS
Sep 13, 2017 08:22 AM
ctheiss
Sep 14, 2015 12:18 PM
djpg2000
Sep 7, 2015 10:36 AM
Regency
Sep 6, 2015 05:47 PM
Squigglez
Sep 4, 2015 07:33 AM
