A/T OIL TEMP (Light) came on
Old Nov 30, 2005 | 04:08 PM
phatdawg's Avatar
What’s up?
On the way back from this Thanksgiving holiday weekend I was driving on a paved 2-lane highway (uphill and curves).
All of a sudden the A/T OIL TEMP light came on. I pulled over and it stayed on for a minute so I turned the motor off. I proceeded to check all of the vital fluids and everything appeared to be OK.
About 5 minutes later I fired it up and the light was off. It did not come on again.
Anything to worry about? Could this be a fluke or is something going on?
Thanks.
Old Nov 30, 2005 | 05:12 PM
eric-the-red's Avatar
If it only came on one time I wouldn't worry about it, if it happens more often then you'll want to get it checked.
Old Nov 30, 2005 | 05:26 PM
4RocRunner92's Avatar
Yes, it it most likely a cooling problem. (If any) Hence the temperature light coming on. On the flip side of your drivers side visor, it tells you what to do in such a situation. You did the right thing. Mine comes on ALL THE TIME....then again my transmission is A PIECE. Like Eric said, if it comes back on get it checked out.
Jun 1, 2021 01:51 PM
Sep 4, 2015 09:27 AM
Sandman
Jul 14, 2015 12:36 PM
Poncho0206
Jul 10, 2015 06:21 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
