New pads and shoes on a 2nd Gen. runner
Old Nov 30, 2005 | 09:09 PM
NRM's Avatar
NRM
ok so i've already bought the pads and shoes, but this will be the first time i've replaced them myself, or serviced the brakes at all for that matter. so is there anything in particular or any tips yall have for doing this? i know the pads should be easy but i've heard the shoes are significantly more complicated. just thought i'd check with yall before i start in on this...thanks in advance
Old Dec 1, 2005 | 08:12 AM
eric-the-red's Avatar
Pads are very easy, just undo a clip and pull 2 pins out. If you find the pins are stuck get a thin nail and bang them out from the other side. Put a tiny bit of grease on the pins before putting them back, it'll be easier next time. You'll need to push the caliper pistons back in to fit the new pads, remove some fluid from the master first otherwise it might overflow.
Rear shoes are a bit more complicated but not too hard. Do one side at a time, keep the other side intact so you can look how things go back together. Make sure you clean and lube the self adjusters before putting them back, use a SMALL amount of high temp grease. Make sure they're screwed all the way in so the drums will fit on, then adjust them. I usually tighten mine up until the brakes are just dragging slightly and then back off a couple of clicks. It's easier if you do it before you put the wheels back on.
Old Dec 1, 2005 | 10:11 AM
NRM's Avatar
NRM
thanks a lot, i appreciate it. i'm gonna try to get them done this weekend if i can get a damn day where its not 30 degress outside
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
MTLroadierunner
Jul 15, 2015 12:58 PM
Steezy96yota
Jul 6, 2015 10:00 AM
HRDC0R19
Jul 5, 2015 06:43 PM
