Very hard shifting when cold?
Old Nov 26, 2005 | 09:11 AM
91RN81's Avatar
Got a problem with my 91 2wd pickup when first started in the morning. It doesn't want to shift into 2nd when cold, sometimes it even grinds pretty bad. 3rd gear is a little stiff but better but also occasionally will grind too. The tranny fluid was changed last year when the shifter bushing was changed. Toyota did it. I'm thinking maybe if I change the fluid to a redline product it will smooth it out, good idea and which kind do i need? thanks
Old Nov 26, 2005 | 10:05 AM
Waterboy's Avatar
Mine is rough when it's cold too but I've learned how to make it work. About a second hesitation between 1st and 2nd and 1/2 second between 2nd and 3rd makes it glide in pretty smooth. If I'm down shifting to 2nd I usually tap the gas and it goes in smoother. Never thought too much of it as all of my vehicles have been harder to shift when they are cold.
Old Nov 26, 2005 | 05:26 PM
Nic's Avatar
Nic
I initially changed over to Amsoil when I bought my truck and didn't like the shifting. I then went to Redline, and it was much better than the original dino oil and Amsoil. It's worth a try, but I wouldn't expect much. You might want to try the "overfill" method too. There are a few posts on it here. I have mine overfilled just a bit too. Have had no problems.
Old Nov 26, 2005 | 09:01 PM
kyle_22r's Avatar
GL5 oil in our trannies tends to make them hard to shift. redline MT90 is a GL4 oil, which is what works best for toyota transmissions. i also noticed in the new amsoil catalog that they came out with their own synthetic GL4 transmission oil.
Old Nov 27, 2005 | 01:23 PM
91RN81's Avatar
so redline GL4 oil i take it? How much will I need? thanks.
Old Nov 27, 2005 | 04:08 PM
Nic's Avatar
Nic
Redline MT-90
Mine held 3 quarts-that just barely did overfill it. If I had ordered 4 quarts, I might have added just a bit more. I don't know how much yours would hold. I would think 3 would be enough, but I really don't know.
http://www.redlineoil.com/products_g...57&subcatID=18
Liadrin
Apr 25, 2022 02:54 PM
Liadrin
Sep 1, 2015 06:44 AM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
crashburnoveride
Jul 10, 2015 06:39 AM
