86 22rte turbo adjustments
Old Aug 11, 2005 | 08:30 PM
adam86pickup's Avatar
Unhappy 86 22rte turbo adjustments
this motor was rebuilt 5,000 miles ago and was rebuilt to original (stock) standards. It now has a boost controller and boost gauge. What amount of psi could be used with this motor that would be a little on the safe side (basically so no detonation occurs). it has the ct-20 turbo on it. stock intake and exhaust. i am new to this motor. any info would be greatly appreciated.
Old Aug 11, 2005 | 08:33 PM
superjoe83's Avatar
before you go cranking up the boost i would recommend to get a air/fuel ratio gauge on it so you can see when you go too much...
Old Aug 12, 2005 | 02:20 PM
what types of gauges are the best to use and which are actually accurate. i need something that has good results and that wont fail.
Old Aug 12, 2005 | 02:27 PM
JEDI87's Avatar
I would get a wideband.You can get them for a few hundered bucks at summit racing or Jegs.The regular ones just give you kind of an idea.
viesail
Sep 21, 2015 06:00 AM
bhaithc
Sep 17, 2015 07:53 PM
shalom
Sep 8, 2015 10:02 PM
viesail
Sep 5, 2015 04:23 AM
moparbay
Sep 3, 2015 12:48 PM
