Too much lift?
Old Oct 5, 2005 | 02:02 PM
4x4Lamm's Avatar
Too much lift?
Do you guys think that OME HD coils, BJ spacers and SDORI coil spaers would be too much lift to fit 32s on a 2nd gen?
I would say just do it and go for 33s, but that means new wheels and I'm not sure how well the autobox will hold up, even with 4.88 gears.
Lamm
Old Oct 5, 2005 | 02:07 PM
Flygtenstein's Avatar
Yes.
Add more tire or less lift.
Old Oct 5, 2005 | 02:13 PM
4x4Lamm's Avatar
OME HD Coils, OME Shocks and steering damper, Marlin Brake Lines, T-Bar crank (to level) and 32x11.50s on stock 15x7s seem good.
Or would it be better to get the BJ Spacers and less T-bar crank?
Lamm
Old Oct 5, 2005 | 02:39 PM
MudMonkey's Avatar
I'm running 33's and autobox w/ 4.10's. No problems.
Old Oct 5, 2005 | 02:46 PM
I wouldn't worry about the tranny.
Old Oct 5, 2005 | 02:59 PM
4x4Lamm's Avatar
I'm not so much worried with durability, but rather performance/MPG.
You and I have the same rig Flag (in stock form)...
How do you feel about the above mentioned lift...
Lamm
Old Oct 5, 2005 | 04:11 PM
Silver_Truck's Avatar
id do it and run 33x10.5s no need for new rims, 4.88s should be fine. euther way bj spacers are better then tbar crank
Old Oct 5, 2005 | 04:54 PM
4Crawler's Avatar
Lots of folks run that size tire with no lift:
http://www.4crawler.com/4x4/ForSale/...it.shtml#FAQ10
Old Oct 6, 2005 | 11:28 AM
4x4Lamm's Avatar
I had 33x10.50s on my last rig, they were ok but the only thing they offered was a little more groung clearance. 31x10.50 would be ideal for MPG and power without being too small, 33x12.50 would be ideal for the wheeling I do. I figgured I would just split the difference.
Do you really think that 33s would not bog down the truck too muc with an auto?
Lamm
Old Oct 7, 2005 | 01:23 PM
4x4Lamm's Avatar
I have settled on OME HD coils, stock t-bars, BJ spacers, LSPV bracket from Downey, brake lines from Pro Comp and shocks and steering damper form OME.
This will allow me to run Cooper Discoverer STT (32x11.50R15s) on stock Wheels.
Lamm
Old Oct 7, 2005 | 02:09 PM
rocket's Avatar
Whats the LSPV bracket? I called Downey and they did'nt even know what it stands for...
Old Oct 7, 2005 | 02:29 PM
4Crawler's Avatar
A bracket to adjust the Load Sensing Proprtioning Valve, on the rear axle, for a suspension lift. Helps restore the factory front/rear brake bias. I make one:
More info:
http://www.4crawler.com/4x4/ForSale/...l#OrderingInfo
Old Oct 13, 2005 | 10:44 AM
ToyoRunner94's Avatar
Sounds like a nice size lift for you want to do. i bought the OME HD springs, coil spacers, BJ spacers and a tiny bit of crank on my tbars. i run 33x12.5 with my stock 4.88 gears. i love the setup. you should consider it in the future if you want to go bigger.
Old Oct 13, 2005 | 11:29 AM
4x4Lamm's Avatar
Do you have an auto or manual ToyRunner?
Lamm
Old Oct 13, 2005 | 11:34 AM
snap-on's Avatar
Load Sensing Proprtioning Valve... biggest POS there is.
pull it out and in place of it put a normal proprtioning valve. MUCH better control!
Old Oct 13, 2005 | 12:53 PM
99_Runner's Avatar
I had a 93 4Runner with the auto and factory 4.88's. I put on a 4" Superlift and 33x12.50 Super Swamper Trxus. I was only getting 13-15 mpg. And the power was really bad, but it did decent wheeling. I wouldn't suggest doing 33s with an auto unless you want to go to 5.29 gears so you can get halfway decent gas mileage.
Old Oct 13, 2005 | 05:01 PM
s_wall98's Avatar
99 runner: What mpg were you getting before the Trxus and how long did they last you?
Old Nov 11, 2005 | 06:24 AM
i have an auto
Old Nov 11, 2005 | 11:06 AM
Randomness's Avatar
Any more info on doing this? I never replaced my "LSPV" after my lift...and I didn't notice any difference.
Old Nov 11, 2005 | 11:22 AM
4Crawler's Avatar
Your rear braking pressure is reduced. You should at least raise the sensing rod equal to the lift eight to restore full rear braking. Here is what I did with mine:
- http://www.4crawler.com/4x4/4R_suspe...ortioningValve
Essentially converts the LSPV into a simple adjustable prop. valve.
Or a simple relocation bracket as I showed earlier will work if you want to keep the stock setup. Or you can do the manual prop valve swap:
- http://www.frontrangeoffroadfab.com/valve.htm
