Rough Idle
Old Oct 13, 2005 | 02:32 PM
iGGz's Avatar
Rough Idle
Alright the ol 4Runner is starting to idle a little rough like it almost feels like its going to die but then when I give it a little gas it sounds fine... but it will just keep going in and out...
I actually had to put it in nuetral a few times at the stop signs to keep it from dying...
Oh and also the engine is clicking like hell when I accelerate... what could be the cause of that...
Sorry so short have to run to class!
Thanks
Old Oct 13, 2005 | 04:10 PM
Elton's Avatar
maybe a vacum leak or just needs a tuneup
Old Nov 3, 2005 | 05:04 PM
iGGz's Avatar
Alright I havent even driven it for like 2 weeks now because there is no need to... but I went outside to the parking lot to drive it around for awhile and when I would stop at a stop sign it would just idle horrible and actually sound like it was going to shut off... the lights and everything seemed a little more dim too... and it actually did die when I got back to the parking lot...
Hum...
Old Nov 4, 2005 | 11:29 AM
iGGz's Avatar
Coughhh
Old Nov 4, 2005 | 11:37 AM
Intrepid's Avatar
My '85 will pull strong on the highway no problem but when I let it drop to idle it stalls. If I ease off the throttle gently it will stay running most of the time but if I just step off the gas and let the RPM's drop it will stall. I haven't figured it out yet. When I do, I will let you know.
Old Nov 4, 2005 | 11:41 AM
Intrepid's Avatar
I don't know if any of these will help you:
https://www.yotatech.com/forums/f2/wheres-maf-22re-47893/
https://www.yotatech.com/forums/f116/how-can-i-tell-if-egr-valve-stuck-open-70059/
http://www.pirate4x4.com/forum/showthread.php?t=161131
https://www.yotatech.com/forums/f2/stalling-symptoms-14525/
https://www.yotatech.com/forums/f2/low-idle-followed-stall-36434/
http://www.tacomaterritory.com/forum...5488&highlight
Sleaker
Aug 26, 2020 06:03 AM
Eggslinger
Jun 8, 2019 03:32 PM
1992pickupSr5
May 9, 2019 08:44 AM
TACOJO
Nov 27, 2015 05:26 PM
markwink
Aug 18, 2015 12:38 PM
