Squealing noise from tranny area?
Old Dec 4, 2005 | 06:00 AM
hektikwon's Avatar
I'm getting a high pitch squealing when my 4runna idles and when I excelerate. It goes away when I put in the clutch and dies down in the higher gears. I'm leaning towards the pilot bearing but I wanted to know if anybody has had something similar to this happen to them .Thanx
Old Dec 5, 2005 | 02:39 PM
hektikwon's Avatar
Somebody anybody? It's annoying me and I want to get rid of it. When I'm in 4th it basically goes away .
Old Dec 5, 2005 | 02:49 PM
rngrchad's Avatar
Maybe speedo cable? They connect at the xfer case, and have been known to make high squeeling noises before going bad. ....disconnect the cable, drive around without your speedometer and see if you have the noise still.
Oh and yes, I currently have this problem...it is horrible but I found out how to fix it. I turn the radio up.
Old Dec 5, 2005 | 02:53 PM
hektikwon's Avatar
Yeah I turned mine up too but my consciousness said "You know the noise is still there, FIX IT" I don't think it's the speedo cable cause it's only a few months old from Toyota.
Old Dec 5, 2005 | 02:58 PM
rngrchad's Avatar
conscious...what's that? Maybe check the cardigan joint. If there is play in it, the u-joints inside it are bad....those squeel when not lubricated enough. Get out the greese gun and give that a shot.
Old Dec 5, 2005 | 03:09 PM
hektikwon's Avatar
I just read a post with a similar problem and they said their input shaft and main shaft were toast. iijust want to know so I can plan my next move.
Old Dec 5, 2005 | 03:38 PM
paddlenbike's Avatar
Pilot bearing. My Supra did the same thing--noise would go away when the clutch was in and would quiet down in higher gears. Replaced the pilot bearing and everything is quiet.
Old Dec 5, 2005 | 04:55 PM
kev93p-up's Avatar
I'd be willing to bet it's the throwout bearing. Time for a clutch.
Old Dec 5, 2005 | 06:36 PM
hektikwon's Avatar
I just did the clutch when I put the 3.4 in. I may have tapped the pilot bearing too hard and damaged it. Just want to be sure before I pull the tranny and redo it. I may swap the throwout bearing also.
Old Dec 5, 2005 | 07:25 PM
Mason Dixon's Avatar
my tranny makes a squealing noise only when i first start it up in the cold
but I have an automatic, any suggestions as to what it is?
Old Dec 5, 2005 | 07:34 PM
kev93p-up's Avatar
Are you sure it's the trans? I've never heard an auto. squeal before.
Old Dec 7, 2005 | 07:29 PM
hektikwon's Avatar
Leaning towards servos. Anybody think differently.
JNapolitano
Nov 14, 2019 07:46 PM
norcal98
Aug 10, 2015 06:20 AM
Athansinis
Jul 27, 2015 08:38 AM
yourrealdad
Jul 21, 2015 11:13 AM
PlayAwhile
Jul 20, 2015 11:36 AM
