- Tachometer won't rev past 2000 RPM (Engine runs normally)
- 1992 pickup w/22re wont stay running
- My 'Charge' and 'brake' lights are flashing on and off
- finding and fitting a (used) camper shell for my 87 shortbed
- ARP 3VZE head studs
- Speedometer not working sometimes.
- Manual windows/locks to power wiring
- 3.0 misfires in a 94 runner
- 87 22r distributor won't seat.
- Starved for gas on VERY HOT day
- 22RE Oil Pressure Sender
- Hello, It's been a while!
- 22RTE rebuild or not?
- Molded hoses
- Turn signal issues
- Replacing input shaft on a w56
- 3vze Intake Manifold Bolts Wont tighten to Torque Specs
- Weasy cams
- Toggle Switch Ignition Help
- Another TVV horror story
- Anyone wear through metal timing guides?
- Newbie 4Runner owner with no spark!
- web site oem part
- I need help!!!
- 22RE issues
- 340H overheating fix I hope
- Transfer Case Swap
- LCE street valve springs
- Trail gear rear bumper
- 22RE AC Compressor belt tension pulley
- New radiator and thermostat installed but...
- 87 5-speed maintenance question
- Out of storage - so to be on the road (again)
- headlights going out randomly
- 91 pickup 3.0 idle issue and rattling noise
- Front wheel spindle torque spec
- 3VZE compression numbers
- Rear axle. V6 vs 4cyl
- Hard start, slow/hesitant acceleration
- Rough surging when in gear at part throttle. Help!
- Ouch! Propeller shaft destruction...
- 22RE Bolts For Header Studs?
- 22re low idle on start does not surge then lower
- 93 4Runner still not shifting after solenoids replaced.
- Cutting out on interstate. Refresh my memory.
- Help..?
- Parasitic Battery Drain 22re
- 1988 3VZE: Conflicting valve clearance specs
- 95 4Runner trans case trans issue
- 22re head gasket failure. 20k
- 3VZE vac line delete
- 1994SR5 4X4 3.0 V6 Issues
- The Addiction Begins
- Ignition timing after new timing chain!
- A/C system swap 22re to a 3.0...
- 32x11.5 on 1990 stock 4runner
- Camshaft woes, could really use some help here.
- Last Resort......92 pickup might be up for sale?
- Gutless 94 22re 4x4 pickup looking to re gear
- Offroad rattles need help door latch and tail gate
- Rough idle, loss of power mystery AFTER idle speed adjustment and overheating
- Odd misfire PLEASE HELP!!
- 87 rough ride OME fix?
- Tire Guru, load and inflation tables
- CVs spinning.. Dumb Question?
- Brake and charge light dimly lit.
- 94 4 Runner brake seized now truck wont start
- Waterproofing a 22re
- 1994 4runner 3.4 swap help
- So let's get into it
- Timing cover fail, help!
- Reflex vs Sparkplug Wires
- Door panel
- Intermittent Code 5 1986 22RE
- occasional starting troube for 89 22re pickup
- Blown Head Gasket or.....? '93 truck 3.0
- 94 PU 4x4 5spd man v6 mystery issue
- 3vz turbo!!!
- Fuel tank filler tube
- Idle drop after any engine rev - 3.0
- Diagnosis help needed 3.0 Automatic
- 3vze oil pressure specs
- 1988 4runner
- Flame thrower injectors
- installed new rotors should I use new pads
- 92 4runner issues!help
- 93 4runner 3.4 swap wiring help
- Welding near ECU question
- 91 4runner 3.0 hot start issues
- tight injectors. 3vze
- After headgasket boil over
- 86 4Runner caps on rear radiator hose ok?
- Play in my hubs after front wheel bearing job
- 90 4Runner sas
- Sensory Input
- W series transmission extension housing oil baffle plate?
- Help with vacuum hoses truck 3vze 1991 4x4 v6
- rear drum to disk brake conversion kit
- Rear axle help on a 2wd build
- Looking for service repair manual 1992 pickup 4x4
- 3vze Intermittent Shutdowns!
- NO OIL PRESSURE, 0 pickup/pressure..??
- Well, my head gasket blew
- Mechanic at a loss.help!!
- Transmission 1993 V6 3.0
- misfires cyl 1&2 PLEASE HELPPPPPPPP
- 99 4runner CEL issue
- Fuel delivery problems
- Fixing Stupid
- Fuel pump issues
- Bumpstop Tech for SAS'ed Yota?
- Imput Shaft Bearing??
- How to adjust e brake line?
- 1987 22r will not get fuel
- Not Sure I like my latest look....
- What is this part?
- Torque Converter
- Truck wouldn't go into gear
- 2nd Gen Engine harness
- Craigslist 4runner
- Help. No 5th or Reverse.
- Crank pulley won't go all the way down on 94 22re
- 3rd member storage.
- 4runner idles at 1500rpm
- A340H transmission troubles
- Nissan Tire Carrier Hack
- 86 auto 4Runner tilt steering loose, side to side play ?
- diff compatibility
- Egr no bs
- What size is this bolt?
- 86 Pickup Sporadically Loses All Power
- Just bought my first 95 4runner (51k miles)
- 87 4X4 Brake and Charge Light staying on after working on brake light switch
- 4wheel drive light.
- Think he wasn't so honest?
- 92 pickup bell housing
- Engine will only rev above 3k if done very slowly
- trans cooler and transfer cooler...
- Gutter Rust Repair
- Idle speed keeps dropping
- 1.9 TDI vs OM617 diesel swap
- Loud Vibration from 1986 pickup
- Exhaust worth it
- hard vibration when foot comes off gas pedal
- Help!
- Where to get bushing for the 555 idler arm
- Missing Radio Mounts
- 2.4 swap?
- can you identify these hoses?
- Fuel filter woes
- Timing adjustment
- Air box
- Help get this truck back on the road!
- ENGINE overheating 3.0 89
- New 4runner
- 3.0 Cams
- Changing/upgrading pulleys. 7" LCE water pump and 4" crankshaft pulle
- I need help with gauge cluster
- 2nd gen lever/handle in cargo area. what is it?
- Experience with Advance Auto Radiator
- Looking for a tonneau cover
- .5Inch shock question
- Thinking about a swap need help!!
- 86 22rte body swap
- 2nd gen clutch hydraulic line photos
- 90 4Runner 22re into 1988 4Runner
- Motor swap 90 runner to 88 runner
- Replacing valve springs with the head on
- Valve Shims
- ECM replacement, what to do?
- Blower and AC not working
- 89 4Runner A340H not shifting code 42
- 3vze bolt and cap question
- will w56 and g54 trans shifter handle interchange?
- Transmission Swap Woes
- 3VZE Timing belt issue
- Brake line splitter?
- Viper security system win
- spindles
- Pics of stock 3rd gens with 31's
- Rear differential pinion seal?
- Possible newbie gear question
- 1992 22re Truck
- Replaceing the a430e to a430h, wiring?
- Infant car seat in 88 ext cab..can I add the LATCH anchors?
- Chain tensioner problem ?
- Looking for Leaf springs between Pensacola Fl. and Chicago Il. Cant sag in the city
- pictures of a 3rd gen truck with trimmed fenders.
- Super Custom '94 Pickup
- Fuel issue on start up
- fuel economy
- bcd1? is it possible?
- Overheating and stumped!
- 87 4runner 3000 rpm
- Replace antenna
- 1988 4Runner Transfer Case problems
- 93' Thermostat Not Opening - New Everything
- Is it possible to install crossover with heads on?
- 87 T4R Power shutting off randomly
- Fuel damper = super noisy injectors?
- Electrical Help 1989 Toyota Truck 22re
- '86 22re idle issues when pumping brakes
- 22re engine trouble
- Need more info Red 1988 SR5 Ext Cab 132,320 orignal miles
- New AISIN water pumps and cracks in the casting - Your thoughts
- First Gen Bumpers
- fuel pump question (5 sec run time)
- Just finished rebuilding the top end and now coolant leaks everywhere
- need help with installing 63's
- Ignition Advance
- 22re - maf & kn filter?
- 1987 Toyota truck starting problem
- O/D Codes on a manual transmission...
- Need a new transmission dipstick tube
- oil pressure sensor - 95 3.0
- Key ignition cylinder removal
- Did I narrow problem to Fuel Pump>
- ECM replacement
- Engine knock?
- How do you keep the A340H cool??
- Steering knuckle bushing/needle bearing grease
- 22r broken connecting rod?
- Check engine light
- 89-95 bed dimentions
- Won't start No power
- Crossover pipe issues
- 2jz bl?
- Seal Dust, 90313-93002
- Seats..Again
- Worried about my locking hubs (after conversion) and rotor/hub discussion
- ECU repair
- Total Chaos Mid Travel coilover question
- Help with possible ignition problem!
- Limp mode, 93 3VZE
- Rod knock?
- calibration on the factory tacho (92 v6)
- 2x electrickery issues. 92 v6 4runner
- 3" body lift and why I should not do it.
- 3vze 95 acceleration/vacuum leak?
- Gearing questions for 3.4 1990 4R AT SR5
- New (used) 94 pickup 4x4 SR5
- 1992 4x4 Steering column upgrade
- Help! Carb re-build fail
- YES Another "'86 4x4 22re running Very hot" thread
- 3vz-e AFM mod
- Conversion of ADD to Manual system
- Problem under a load
- 4 cylinder brake rebuild thread
- Towing 87' Xtra Cab
- Testing rear window power switch (up/down)
