4wheel drive light.
Old Jun 3, 2016 | 06:14 AM
Trust one's Avatar
4wheel drive light.
Hi this is my first post thanks in advance for your reply.i have a 1994 Toyota pickup Sr5 model, and i notice when i am driving around 50 or 60 miles a hour my 4wheel drive light flashes on and of but does not do it at lower speeds. And yes the 4 wheel drive works goes in and out smoothly.what could be the problem thanks.
Old Jun 3, 2016 | 07:12 AM
92ehatch's Avatar
I'm not sure how the light is activated but if it's operated by a switch on the transfer case then the switch could be bad. If it's a ground style switch could have a broken wire or shorted wire causing it. Depending on the style of switch.
Either way that is easy to check until someone who knows how the light is activated chimes in
Old Jun 3, 2016 | 07:20 AM
Trust one's Avatar
Thank you 92ehatch for your answer.if anyone had a picture that would be great.
Old Jun 3, 2016 | 05:54 PM
92ehatch's Avatar
It is a switch mounted on the transfer case similar to the reverse switch on the manual trans.
Wire is broken and shorted, or switch is bad
Should be easy to find and fix as is the only electrical connection on the transfer case.
kawazx636
Mar 23, 2023 09:37 AM
alva22re
Feb 20, 2016 04:21 PM
goofybud16
Feb 6, 2016 01:29 PM
CLin9383
11
Sep 7, 2002 05:28 PM
