22re head gasket failure. 20k
Old Jun 18, 2016 | 10:23 PM
Shagool22's Avatar
As title says my 1987 4Runner blew a head gasket at 20k on rebuild.
Bought a long block a year ago from a local rebuilder that I've heard good about. I installed longblock myself.
Here's some pictures of the head gasket. Was hoping maybe somebody could help me figure out maybe why it failed.. I know nothing about head gaskets.
To me it looks pretty clear it failed between water jackets on 2 different cylinders.
Is it cheap head gasket? Improper installation? Or do I need to just slow down a bit lol? Yes I torqued to spec before installation and after after 1000 miles as per the engine builder told me to.
Truck never overheated. Ran flawless. Just started blowing lots of white smoke so I parked it until I could tackle it (knowing it was most likely HG.)
Thanks for any input much appreciated. I want it to be done right this time so I hopefully don't have to do this again in another 20k..
Old Jun 19, 2016 | 01:02 AM
wyoming9's Avatar
Do you mean short block ??
Long blocks come with the head .
Unless you bought it all in pieces in which case it is just parts
As for the failure sometimes you never can tell it could be a few things.
Slight flaws in the head gasket
Block or head not completely straight
Only a few thousands might cause a issue.
Some thing caused the head bolts to give a false reading when torqued
Over the years I had a few that it just happened never could figure it out I figure Mr Murphy and his daughters may have been the cause
Old Jun 19, 2016 | 07:40 AM
ZUK's Avatar
ZUK
Looks like a good quality metal HG.
Are those scuff marks in the bore from overheating?
Was the original engine replaced for a blown gasket also?
Old Jun 19, 2016 | 08:00 AM
Shagool22's Avatar
No I meant longblock. I bought it complete block and head ready to go valves, rocker assembly everything already installed.
And yes I have a factory HG ready to go in.
Ill just try to do everything by the fsm and hope all goes well.
Thanks for the input wyoming9
Old Jun 19, 2016 | 08:07 AM
Shagool22's Avatar
original engine through a rod through the block at 145k factory engine
It the. Sat for 15 years in my dads shop and he gave it to me. So I put the longblock in.
I noticed those scuff marks as well. It never once overheated. The second it started blowing smoke was right when I pulled into my driveway. Pulled it in the shop and parked for a couple days before I could tear into her. I have an aftermarket temp gauge. Never broke 195 zuk
Old Jun 19, 2016 | 09:05 AM
Shagool22's Avatar
Here's some pics of the bottom side.
Old Jun 19, 2016 | 09:14 AM
Shagool22's Avatar
The whole exhaust side of the HG is smoked.. That whole side you can see every indentation from head and block. Is it possible that side was over torqued? Just doesn't look right to me
Old Jun 19, 2016 | 01:49 PM
Flash319's Avatar
I would chaulk it up to a crappy gasket. That looks like excessive deformation and garbage lamination. 20k is not that much running for such a crappy looking gasket. If your just doing the head gasket go with an OEM. My 2 cents.
Old Jun 19, 2016 | 04:42 PM
cbr600rx7's Avatar
He is dead on. If it's a near stock motor OEM Toyota gaskets tend to live for a long time. I would stay away from the hard core aftermarket gaskets unless you are having the block and heads both surfaced.
Old Jun 19, 2016 | 10:45 PM
Shagool22's Avatar
i was leaning towards the same thing... I could tell the difference in quality between this gasket and my Toyota OEM HG. Got her all back together and she's running great.
3fingersalute
Mar 16, 2016 08:09 AM
ladybugRC
Feb 18, 2016 04:50 AM
Oskr Morán
Feb 11, 2016 04:46 PM
BlackRunner
Jun 17, 2002 07:49 PM
