Truck wouldn't go into gear
Old Jun 5, 2016 | 06:06 PM
oregonducktaylor's Avatar
88 Toyota pickup 22RE 4wd-I was playing in the woods and I came to a stop and tried to put it in gear and it wouldn't go into any gear. Also when I tried to put it in reverse the gears grinded. The truck wasn't rolling forward and I could get it in gear with the truck off. Also new clutch about 6 months ago. Weird thing is this morning it wasn't doing it. Could heat have affected something? Any thoughts as to what is causing this?
Old Jun 5, 2016 | 08:01 PM
millball's Avatar
Likely some sort of hydraulic failure.
Got any fluid in the clutch master cylinder reservoir??
Fill, bleed and go from there.
Old Jun 5, 2016 | 08:17 PM
Yes I do. It is not the prettiest color though? Could it be the slave master cylinder?
Old Jun 6, 2016 | 10:25 AM
highonpottery's Avatar
clutch MC and slave cyl should be done at the same time. they sometimes go internally with no exterior signs of failure. first try simply flushing and bleeding the system to see if some debris from a seal got stuck
Old Jun 6, 2016 | 12:10 PM
osv's Avatar
osv
look under the bell housing at the clutch arm, see if it moves while someone is pressing the clutch pedal in the cab.
Old Jun 6, 2016 | 07:03 PM
Alright thanks I'll just go ahead and replace both of those!
dixiemuddtoy
Oct 24, 2024 06:16 PM
SueLu
Feb 24, 2016 08:23 PM
alva22re
Feb 20, 2016 04:21 PM
Antonio Cadiz
7
Feb 11, 2016 01:15 PM
goofybud16
Feb 6, 2016 01:29 PM
