Blown Head Gasket or.....? '93 truck 3.0
Old 06-13-2016, 10:44 AM
Remme's Avatar
Truck would start, idle briefly at about 400 rpm then die. Battery is new, truck was just tuned up in March and was running flawlessly until now. Checked the oil, it's clean and filled sufficiently. Checked the radiator and the fluid was clean and filled. Something made me check the coolant overflow and I found it to be brown and smelled burnt (see picture). Is this a sign of a blown head gasket?! I stopped there so I haven't checked the other maybe symptoms such as the fuel pump because the "oil" like fluid in the coolant overflow made me instantly think bad head gasket. I haven't checked for compression yet....What do you think?
Old 06-13-2016, 11:00 AM
millball's Avatar
Too soon to tell.
More investigation by you is necessary.
Old 06-13-2016, 11:58 AM
Janos01's Avatar
A few signs of a blown HG are:
  • Milky oil (water in oil)
  • Excessive white smoke out the tail pipe
  • Having to add coolant often
  • Strong smell of antifreeze
If you are mechanically savvy, I would remove the spark plug on cylinder #6 and get a bore scope (dont know the exact name) and look into that cylinder. If you see water in the cylinder, you have head gasket issue.
cascadia
07-24-2016 09:45 AM
Joey22r
02-27-2016 04:24 PM
gixxer
02-18-2016 06:17 PM
ethanethan
02-16-2016 06:10 PM
BlackRunner
06-17-2002 07:49 PM
Quick Reply: Blown Head Gasket or.....? '93 truck 3.0
