CVs spinning.. Dumb Question?
Old Jun 15, 2016 | 07:48 PM
Rory Jackson's Avatar
Hey there everyone!
Here's the sich' :
1995 4Runner 3.0 V6 5 speed 4WD
When I bought it it had Aisin locking front hubs.
Recently did bearings, rotors, brakes, and balljoints both sides on the front. Apon reinstalling the hubs (yes the turn to free and lock just fine) and having the vehicle jacked in the front, still in 2WD mode : I spin one front tire and notice the cv is also spinnin, this happens both in lock and free. Is this normal? If it's in free shouldnt the wheels spin indepently of the CVs to avoid wear? Dumb Question I'm sure. But help would be appreciated!
Thanks in advance!
Old Jun 15, 2016 | 07:56 PM
millball's Avatar
Must not be unlocking.
Does the wheel turn if you turn the half-shaft??
Old Jun 15, 2016 | 08:14 PM
Half shaft ? That being the shafts coming from the sides of the front diff? Sorry, I'm new to working on driveline components
Old Jun 15, 2016 | 09:27 PM
Turtl3's Avatar
Yes, half shaft/driveshaft/cv shaft/axle shaft. There may be enough reistance inside the hub that turning the wheel also causes the driveshaft to spin. Can u hold the shaft stationary while the wheel is spinning?
Old Jun 15, 2016 | 11:19 PM
wyoming9's Avatar
The better question is will your axle turn with the wheel on the ground??
Old Jun 16, 2016 | 02:41 AM
wallytoo's Avatar
^^ good idea.
also possible that the internal hub is not an IFS hub, but is instead an SA hub. if so, it won't disengage from the axle splines, even when in 2wd position.
Old Jul 31, 2016 | 12:06 PM
Hey everyone sorry I've been away. Managed to fix it. turns out that I reassembled the locking hub incorrectly. Everything is all good now and working fine on that front! thanks
Agent Orange
Aug 5, 2016 09:28 PM
mad_sb
Jul 2, 2016 06:47 AM
fruitstripe
Jun 16, 2016 05:18 AM
Trd95sr5
Jun 3, 2016 07:52 PM
L4g63t
Jun 3, 2016 08:53 AM
