- Floorboard
- Knock sensor confusion
- 4wd not working
- 3vze Engine that cuts off gearbox in D mode
- Installing newer surge tank on 1987. eliminating IAC
- 88’ pickup 2WD auto leaking from rear of transfer case
- 87 pickup temp/oil pressure/rpm gauge failure
- Bad ECU or diagnostic port???
- 1988 Pickup Engine Parts
- Diagnostic Errors: “No Ne signal”, “KS signal has not reached…” / ECU Replacement?
- 92 22re timing issue
- Dash Dials and Turn Signals Inop 88 SR5 4 Runner
- 90 4Runner Build w/ a 300D OM617.952 engine swap
- Side Mirrors
- 2nd Gen Toyota 4Runner LSD question.
- Keep OEM CV Axle Cores?
- Missing TB Bracket
- 1990 3vze 4runner lost all power while driving
- Replacement Head/CAM
- Upgrade keys/locks?
- Cannot get rocker arms to line up at top dead center
- Brand new LCE 3vze headers for sale
- 1991 Not going into Park
- Cold Start Injector not receiving power
- 3VZE idling rough and rich
- 91 4runner 3.0l
- Preparing for a 15k mile Trip to Alaska
- Turbo concerns
- 91 truck engine swap help please!
- 1st gen '86 4runner problems
- I’ve thrown the book at this damn thing. Jerking bucking backfiring lack of power.
- cant find short
- 1986 22re whistle/ringing
- Anyone know the bore size for the manual locking hubs on our 1st gen 4Runner ?
- SR%, changing ignition lock cylinder
- quirky engine start (22RE)
- 3VZE Ignition Coil?
- Question about getting a blown head gasket fixed
- 90 4runner 22re fuel pump hanger/bracket universal fit?
- Interior Screws?
- Yet another mount question(s)
- 1st Gen Tailgate Torsion Bar Clips
- Anyone got a 1st gen 4Runner in the newer Toyota army green color ?
- 88 vs 89 3VZ-E differences?
- Mystery wire - need help identifying
- '93 3VZE Mystery plug?!
- Help with voltage fluctuation 3VZE
- '89 pickup, replace rear window glass?
- 93 pickup 22re intermittent check engine light
- 1989 pickup with 22r
- 30x9.5r15 hurt or help mpg?
- 93 4runner ECM? Codes: 14,24,31,41
- panhard bar bracket
- Battery & Brake Dash Lights On while running '87 4Runner
- 90 4runner corner light or DRL issues
- Advice on windshield frame rust repair
- Clutch advice
- One size does NOT fit all.
- 95 Toyota 22re idling too high
- Full Quarter Panel Replacement
- Warm Restart issues on 1986 22re. (SOLVED, Maybe))
- Will not go in gears after driving
- Towing a pickup with a pickup
- Lost Most 12v Power 86 Toyota 4X4 Pickup
- 1993 3vze misfire when in park
- 2WD 3.0 V6 Pickup Owner's, I need a measurement please
- Should I use "high mileage" oil?
- Loping engine
- wiring in a chmsl light on headache rack
- 86 4Runner 22re TPS
- 1990 4Runner tailgate window work intermittently
- 1990 4Runner do locks won't work on one side
- 87 4runner brake booster
- Cold Start Injector Wiring from scratch
- Knock sensor wire location ecu connector
- Tried searching and reviving a thread nothin so heres the plague clutch problem
- 1990 Toyota Pickup good Off-road?
- 22RE cranks but won’t start
- What speakers did you upgrade to?
- Slide out Cupholder fix FINALLY
- HELP! New to Yotatech. Replaced cam now no start.
- Looking for a grill guard for my 91.
- rear shock problem
- Broken conical spring on shifter lever. Can spring be replaced?
- Gauges not working
- HELP!! I have a 90 pickup sr5 ext cab, need help with seatbelts asap
- Sold my baby and my nemesis
- 95 4runner shifting issues and transmission issues
- discontinued igniter
- W56 HD build at home - upgraded input bearing
- 1986 4runner radiator replacement
- 1987 EWD on eBay
- tracking down a knock
- Slave cylinder hose and bracket
- Recommendation for H6054 Conversion to LED
- Weird noise, is it serious?
- 89 4Runner new clutch master cylinder & slave cylinder and still won’t go into gear
- Fresh rebuild, runs great until it gets warm.
- 91 4runner headlight options
- Help please 87 22rte
- source for guage bezel cover ?
- replacement springs for my 1989 4Runner?
- 88 Pickup heater control removal?
- Instrument Cluster Lights
- Will 2001 oem 4Runner wheels fit on my 1988 4Runner
- Diesel Help!!!
- 3VZE Diagnostics
- Name this part
- Losing Brake Pedal Pressure After Warmup
- 95 4Runner ECU 2.4 vs 3.0 same?
- 1st Gen Rear Defrost
- A340H Transmission Problem
- Center Support Bearing on Driveshaft
- Trail gear front bumper?
- CA Emission Fail
- w56 - metal pin stuck to transmission drain magnet
- Tailgate stays for 1995 4Runner
- Gas coming out of overflow
- Does this coolant hose kit fit a 93 4runner 3.0?
- 91 4Runner rear coil conversion
- 3.0 to 3.4 engine swap nightmare.
- What shocks/struts to get with a 1.5” Ball Joint Spacer lift?
- New Marlin built rear 3rd member doesn't fit my 8" carrier
- Power window help- doesn't make sense
- CEL P0773 on a 93 with a 99 motor
- Missing 4x4 and CEL graphics
- Engine rpms drop under certain conditions.
- Small but important question
- 3.0 rough idle, code 26
- Help sourcing front grey bench replacement tweed upholstery
- Old fuel contaminated EFI.
- Rear Bumper Replacement Ideas
- Clutch on 1992 Toyota pickup
- 94 to 89 Dashboard swap?
- 87 turbo acting strange
- Strong / rich gas smell coming from exhaust 1993 4Runner
- Quick question about the rear windows
- 1992 3.0l edit relay issue
- Turbo owners, I need your help!
- A340H #4 solenoid part number?
- 86 4Runner Turn Signal Switch Part
- 86 4runner window
- 1993 4runner r150 (3.0) will not go in Reverse
- Wheel bearing clicking
- Part ID
- Need help identifying part
- Mint 4runner. Questions/concers/BAT
- 93 pickup 22re, not going into closed loop? Searched for hours, no answer...
- Electrical plug identification / PLEASE HELP!
- no check engine light - no start - '87 22re
- A.D.D axle shaft vs. Manual axle shaft
- Starting issues, loud click....then no power! please help
- Help with strange sound from motor
- [86 22RE] Would anyone please kindly tell me if my engine sounds normal?
- 5VZFE swap into 1995 (NOT Tacoma!) 2WD short bed truck?
- Tons of parts for sale.
- 95 auto 2wd 4runner Throttle valve cable help
- Injectors not firing
- PO electrical modifications
- W56 Transmission Reseal
- Power Side Mirrors?
- Wiring Harness
- 3.0 lugs at speed
- 22re engine bored .20
- 4RNR Driver Seat
- Trim removal 3rd gen 4runner
- '93 22re Bogs on Acceleration
- 5th grear & Bearing Removal How to
- 3vze Turbo Build (In progress)
- 1994 22RE classic tune-up issues!
- 3.4 swap purchase
- YJ bastard pack?
- Can't get trouble codes to show
- Vehicle speed sensors
- Power mirror options
- 3VZE 277K miles. Rebuild bottom end during head gasket job?
- 1993 4runner driver's seat
- U-Bolt help
- 86 Pickup: Unplugged component by Trans Speed Sensor
- 1992 Tacoma issue with turn signals
- Leaning out at WOT
- Fuel Pump Replacement Fuel Line Hard to Loosen
- What is this clip on fuel injector?
- stuck rear brakes
- 1992 Toyota PU 22re throttle delay. Help please
- 22r engine mounts
- 3rd brake light assembly install
- 91 Truck 3zve How bad can it be
- 93 4Runner sticking clutch pedal - removed return spring
- 87 22r 5spd Pickup Loud Hissing Under Acceleration
- Grinding noise front driver side wheel 91 pickup
- Finally, progress on bodywork on the '87
- No fire/signal to dizzy? So confused!
- No power under load
- Crank, No Start 95 3VZE 4Runner
- 1991 4runner suspension and driveline greasing points help
- Bench to Bucket Seating
- 1986 Pickup AC conversion
- 95 VZE poor fuel economy
- 1st Gen 4Runner Vinyl Flooring around wheel wells
- 1995 4Runner transmission question
- Prestone Flush 'N Fill kit?
- LSPV leak/no leak ?
- Hesitation and Stalling
- The effect of Engine Restorer on my 22re
- Help with Cruise Control
- Is my truck totaled…?
- A340H shifting but not shifting
- Accessorizing...
- Question re: selling 2nd gen 4Runners
- Truck cuts out
- Clutch pedal bracket question
- 1989 Asian automatic trans and a 22RE
- 87 turbo
- 1987 60amp to 70amp alt
- Whining new alternator on 87 PU. 22R engine
- '88 22RE wandering idle + stall after 20-30 minutes
- Less power with rebuilt injectors and diesel pump
- 7mgte swap into ‘93 2wd pickup
- Clutch Kit Delima
- Need help finding sensor part number for electric cooling fan control
- Head lights turn on AC
- Rebuilt head spit out a valve shim!
- 1990 2wd 3vze speedometer cable
- My ‘89 4Runner “Build”
- ˇHeadlight&signal light advice!
- Front end options.
- 86 22re Messed Up By Shop
- Tow hook bolt size?
- Help identify this wire under dash
- 2022 6 lug stock tacoma rim on a 90 4x4 will it fit?
- 1994 Toyota Pickup DLX 4WD Bed Restoration
- Kieth Black 22re
- 1986 Pickup, ARB OME CR009S leaf springs too stiff and too high, drive-line vibration
- Another injector pulse thread......
- Oil pressure sensor connector
- 1991 1ton dually build
- 94 Toyota Truck, hope I'm in the right forum
- Floor Pans
- Power Steering not working anymore
- Diff question
- 1989 heater hose part number
- 88 Toyota Pickup Block and Head Identification
- 1988 Toyota Pickup 22re what plugs are these?
- 1992 4runner 22RE
- 2000 Toyota Pickup from Iceland
- 1988 Toyota Pickup 22re Knock Sensor and Oil pressure sensor
- After years on the hunt, finally got mine! 1992 22RE pickup
