Yet another mount question(s)
Old Dec 1, 2022 | 10:34 AM
DeClercq's Avatar
So I'm looking to replace my motor mounts (again). I had the origional ones replaced a couple years ago with cheap ones (I know, I know...) from Rock Auto. I've got a ton of vibation at idle. I'd like to replace with OEM this time. I'm having a hard time figuring out exactly which ones to get.
According to Yotashop.com, they are part number 12361-65011 and they say it fits both the 22re and the 3.0. However when searching that part number at other online part stores (parts.toyota.com, etc...) they say that part number only fits the 3.0.
I've also found part number 12302-35120 that appears to be for the 22re but is quite a bit more expensive then the one above (~$50 vs. ~$100).
So I guess my question is does anyone know for sure which of the above part numbers would work? Either one?
Also is part number 12381-54020 (Stabalizer, engine mounting) required (I think it's only for the dirver's side mount)? It wasn't reinstalled whent he mounts were swapped out the last time.
Any input would be appreciated.
Thanks!
To clarify: I have a '91 pickup, 2wd, 22re
Old Dec 1, 2022 | 11:13 AM
JoeS's Avatar
I bought a set of 1986 Toyota OEM 22RE engine mounts from my favorite online dealer- Conicelli Yoyota in PA. They came with the steel engine mount brackets blocks specific to each side.
Part numbers are listed. Looks like the 'right', side mount is not available. The rubber parts are the same for each mount.
https://parts.conicellitoyotaofconsh...engine--mounts.
doozer96024@gmail.co
Mar 17, 2019 07:43 AM
nnywg
Apr 17, 2018 04:36 PM
shawnphoto
Feb 26, 2013 01:07 PM
CitrusTheDragon
Feb 25, 2012 07:57 AM
88Yota4runner
Feb 14, 2008 02:53 PM
