Pre 84 Trucks 1st gen pickups
Transmission ID & Help
Old Apr 17, 2018 | 04:36 PM
nnywg's Avatar
Exclamation Transmission ID & Help
Hi all - new to the site but not to old timey yotas. Long story short, I've got a pair of N10 Hilux's, both Canadian, one's a 71 and the other a 72. Both have 18R motors believed to be original. Here's where $#!+ gets weird though:
Truck 1 - Transmission Casting # 33111-30050 - Mount does not match N10 Chassis - Mount does match the part suggested by RockAuto - Mount # A2409
Truck 2 - Transmission Casting # 33111-05352 - Mount does match N10 Chassis - Mount does not match the part suggested by RockAuto
So seems clear to me that the Truck 2 has the right transmission in it. Not too sure how to get the right replacement transmission mount though. Unfortunately a previous owner of Truck 1 hacked up the frame cross-member to to get the wrong transmission mount to fit (same alignment but wider bolt pattern). It's also interesting that the mount has failed on that truck completely since the work was done unknown years ago.
I believe these are L40 and L42 transmissions but have no way to back that up.
Looking for any insight on the above. I can't find a single hit via Google on Truck 2's casting number. Mainly trying to figure out what I have and how to replace the mount on the mystery trans.
Edit: This ebay ad in Spanish is the closest thing I've found to useful information. "There are two different mounting locations on rear extension housing; on earlier models the mount is located further back. Late models have the mount located forward near the case." The opposite information is true in my case but the Corona may be a different story from the Hilux.
jacobtodd123
Feb 25, 2015 07:53 PM
92yota92
Engine Swaps
Dec 4, 2013 10:48 AM
sjdiesel
Sep 12, 2007 05:52 PM
