1990 4Runner tailgate window work intermittently
Old Nov 16, 2022 | 11:06 AM
Haaklord's Avatar
So here is another issue with a tailgate window. When I want my window to work I usually need to start the engine then press the button on the center console to roll it down 10-30 times and it will start rolling down one of those times. Each time I press the button I can hear a click. It can roll down when the engine is off but I usually have to press the button more times. Trying to roll it down with the key from outside is even less likely. It rolls down better when it is warm out (???). The window rolls up every time with any method. Once the movement starts it goes up and down with good speed so I don't think the motor is the issue. I feel like this may be a faulty relay that only gets a connection every once in a while. Does anyone have an ideas on this?
Old Nov 16, 2022 | 11:09 AM
Haaklord's Avatar
It's also worth mentioning (I think) that the rear defroster and rear wiper both don't work. Not sure if all the relays for these might be in the same place or something and a sign of a bigger issue.
Old Nov 16, 2022 | 11:14 AM
87-4runner's Avatar
Check the grounds
Old Nov 16, 2022 | 11:16 AM
Haaklord's Avatar
Originally Posted by 87-4runner
Check the grounds
That would make sense, where do I find these? Inside the tailgate by the motor?
Old Nov 17, 2022 | 02:00 PM
SnipedYota's Avatar
Also a possible short I know at one point mine had a mouse in the rear passenger quarter panel messing up wiring for me.
Old Nov 17, 2022 | 06:28 PM
dRgordy's Avatar
have to find out where the wires go and test for any breaks in the wires
jay4runner
Jul 14, 2021 03:22 PM
Scott Mcgill
Aug 5, 2019 08:06 AM
Brennan Turner
Dec 18, 2013 01:53 PM
bozz
Mar 16, 2008 07:38 PM
fooddude
7
Dec 17, 2003 12:16 PM
