LSPV leak/no leak ?
Old Sep 10, 2022 | 05:40 PM
TnT#2's Avatar
LSPV leak/no leak ?
Hello, 94 Ext. Cab 4x4 22re. Lspv has been doing it usual, leaking ! The past two days i have not had to add the usual amount of fluid that normally put in every day !! I keep a drip pan under the right rear wheel to catch the fluid, versus spotting up my carport and driveway ! The past couple of days maybe three days there has been minimal drips and leakage. I usually have to put in maybe almost half of a soda can every day !! What could be causing this ? I know it needs replaced ……. here is another instance. This past winter December January of this year, I hardly added any fluid for two months not even half of a soda can !! …Boot on lspv frozen ? Idk. Any thoughts ?? I know the cure is to replace the lspv , money doesn’t grow on trees these days so I have been saving up some money to replace every component on the brake system to include the lines. Because I know that when I go to take those three lines off of the valve they are going to break ! Thankyou
Old Sep 11, 2022 | 03:15 AM
wallytoo's Avatar
with a known leak in your brake system, you shouldn’t be driving the vehicle, period. you are endangering everyone you cross paths with, including yourself. fix it!
Old Sep 11, 2022 | 07:59 AM
TnT#2's Avatar
Thank you! Your exactly right i shouldn’t be driving it ! But i do on our 329 acre farm and property ! It is not licensed, it is a farm use vehicle !!! I hope a couple of nice bucks i have seen cross my path if anything. But i will park it til its repaired ! Again thank you for information I already knew.
Old Sep 11, 2022 | 08:28 AM
wallytoo's Avatar
you left out the details that you were not using it on the road. less problematic; at least you aren't endangering the general public.
the lspv is pretty simple. disconnect the hard lines, unbolt the lspv body from the chassis, and inspect it. i guess you already knew that, though.
Old Sep 11, 2022 | 10:28 AM
snippits's Avatar
About five years ago, the LSPV was leaking on my 92. I bought the Toyota part which was very expensive. Took the boot off the LSPV, and water, brake fluid, and a rusty mess came pouring out. Could not afford a new boot kit. Five years later it's still working fine without a boot on it, but I don't do any off road stuff. Just a point A to B and B to A grocery getter, and hauling what ever. You might want to get a boot kit too when you install a new LSPV.
Old Sep 11, 2022 | 01:52 PM
Jimkola's Avatar
YT Community Team
5 Year Member
I bought the boot kit off Amayama. Price was pretty good. The kit actually comes with quite a bit of stuff.
Old Sep 14, 2022 | 12:04 PM
TnT#2's Avatar
Thanks ! Just part laziness as well lol
Thrawn
Oct 16, 2017 11:29 AM
SleevelessSteve
11
Aug 26, 2009 11:52 AM
bpeterson
Mar 11, 2008 07:45 AM
jacumja
Oct 11, 2007 07:56 AM
jus4fun
May 8, 2007 07:29 PM
