4wd not working
Old Dec 22, 2022 | 12:03 PM
Toy95's Avatar
4wd not working
On a day like today 4wd decides to up and bite the dust. I have a 95 4unner with the 3vze and an automatic transmission. Issues with the unit that will not lock into 4 high or 4 low. I did have problem a couple years ago with the ADD system on this thing and decided to bypass the unit and run the system off a switch to engage the 4wd. Earlier this year I was having issues with a nasty vibration on this unit and found the rear output shaft on the transfer case to be loose. Don't know if that lil piece of information helps. I'm just trying to figure out if i need to replace the transfer case on this unit or is there a quick fix?
Old Dec 28, 2022 | 05:42 PM
coopster's Avatar
From: exo-reality -wave if you see me; Front Range, CO
Isn't the t-case integrated with the rest of the transmission casting on the auto?
Littlebird
Nov 29, 2022 07:03 PM
CGS
May 28, 2015 11:44 AM
Brend2b
Dec 10, 2012 11:22 AM
CoalHillsMckracken
9
Sep 14, 2007 02:42 AM
