A340H Transmission Problem
Old Oct 27, 2022 | 09:35 AM
kc4yvv's Avatar
Hello
my 1991 4runner I've had since new, transmission acts up only when cold.
may slip momentarily in foward but after it catches, it is all good from then on. Foward is good in all gears including overdrive.
Reverse on the other hand is not available or slipping until it is warmed up.
It is solid as a rock after it is warmed up. no slip at all.
it has been flushed recently and fluid level is correct.
it has been going on for 8 months approximately.
it wasn't an issue in the middle of summer.
any guru's out there with any idea?
thanks for any help or comments.
Old Oct 27, 2022 | 10:06 AM
scope103's Avatar
I am not a guru. In any sense.
The FSM points out only two on-vehicle-servicable items that might lead to slipping; the linkage and the throttle cable. The adjustment of each can be found here: http://web.archive.org/web/201408160...32prelimin.pdf
Old Oct 27, 2022 | 12:14 PM
kc4yvv's Avatar
It all points to being at operational temperature.
reverse will not engage until idle down warm up. Forward works when cold and on high idle.
it is a controls issue because it all works well after warm up.
jrock24
Apr 29, 2014 11:21 AM
kwj23452
Jan 18, 2011 05:34 PM
Joey Link
9
Jan 11, 2008 04:27 AM
rdiggidy
7
Feb 3, 2006 01:10 PM
maguirre
7
Aug 12, 2005 07:43 PM
