PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 [213] 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. A little engine swap info needed.
  2. Valve Cover tightness
  3. 4Runner Shifter boot material
  4. Front grill and Headlight Question
  5. Leaf Springs - Axle Allignment! :(
  6. '91 4runner died & won't start
  7. Good Or Bad
  8. Welding the spider gears?
  9. Turbo timer
  10. 91 4runner fires on ether but wont start
  11. 88 3.0 will not start - Code 14
  12. What should I expect
  13. 285x75x16R fitment HELP
  14. Vaccum help
  15. timing question 22re
  16. parts trucks.... what to do with engine
  17. Drive Shaft Maintenance diagram
  18. Power Steering Flush
  19. Troubleshooting 3vze after rebuild
  20. intake and exhaust question
  21. 4wd truck turns into bucking bronco
  22. Speedo Question
  23. Going on a long trip Sunday
  24. Cause for concern?
  25. O/D Off light
  26. Transfer Case Leaking Oil Please Help
  27. Right side hud isnt locking
  28. Got some stuff today
  29. E-brake broke and fixed itself???
  30. broken gas gauge
  31. No reverse lights or license plate lights
  32. 1990-95 4RUNNER service manual link
  33. Timing Chain Help
  34. ***Missfire***
  35. Is my speedo off?
  36. Starting problems
  37. 4Runner
  38. Man....I am about to drive myself and this toyota off of a cliff.....
  39. finally got a sfa
  40. 2nd Gen Runner 3.0L Fuel Mileage - zomg!
  41. 4Runner to Tacoma Tire/Brake swap
  42. Ebay hilux clear tail-light lens
  43. What does the SST 09843–18020 look like
  44. Newbie looking for input on first build, fuel milage, and 5.29's with 31's
  45. Anyone know how to wire a tcase motor?
  46. How to Remove 87 Dash Pad?
  47. OME lift info.
  48. 88 plow lights wiring
  49. A question about alternators:
  50. Best Swing Out Tire Carrier?
  51. Head Gasket????
  52. Water Pump Pully $768.99!!!!!!!!!!!
  53. 31's on a 92
  54. Idler arm rebuild woes
  55. My 4runner is leaking coolant!
  56. Will this work?
  57. suspension questions
  58. bumpers and sliders
  59. would it fit?
  60. slave cylinder removal installation instructions link
  61. vibration damper removal
  62. LCE Header
  63. Burping the radiator
  64. Nice e-bay find
  65. ARB Snorkel Install
  66. stallin gout on decents
  67. New radio install issue
  68. so is it just me or are v6 and 22re 4runners wired differently door?
  69. Rear lift dilemma
  70. To trust the nerf bars, or not?
  71. 88 4runner 3.0 in a 95 4runner?
  72. Hydraulic clutch feels like a cable clutch
  73. Oil Leak Help!!
  74. moaning 1990 4runner
  75. 22re Hi-idle and code 43 ECM?
  76. These cant be low on fluid? tranny and TC
  77. Squealing 94 22re
  78. Very slow warm up?
  79. new exhaust!!!!!!
  80. Testing the Brake Booster
  81. One Quick Gearing Q
  82. durned electrics
  83. 93 4runner SR5 Tach issue...help
  84. AT lines, Rear Heater lines...
  85. Towing questions on 89 4x4 Pickup w/22RE
  86. corbeau seats
  87. Overheating after new Radiator.
  88. Smittybilt front tubular bumpers
  89. Auto trans shifting? (I searched)
  90. quieting a 4R
  91. how hard is putting a stock rear tire carrier
  92. 88 Pickup rear blocks
  93. 2.4 tbd
  94. 32x11.5 R15 on 94 pickup
  95. Loud ticking on warm up and in gear
  96. Wheres the fill plugs?
  97. BDS 5500 shocks. Any good? Did I get screwed?
  98. exhaust re-location question
  99. Problem with my truck
  100. Stock T Bar size and leafs?
  101. Out of state and having 3rd-4th gear problems.
  102. HELP!! 90 4Runner won't start
  103. Can I permanently lock my ADD with this tranny?
  104. 1st gen vs. 2nd gen shifter/ clutch hydraulics
  105. Will a 95 bumper fit a 91?
  106. Mystery Manual Tranny Vacuum Port
  107. New rear brakes - is there a "break-in" period?
  108. marlin crawler bumpers
  109. clutch issue?
  110. Header clearances
  111. Exhaust-what size?
  112. Tips for timing chain with IFS?
  113. Clutch, Slave Cylinder, or Master?
  114. no power when warm
  115. for you IFS freaks flex results vs a SFA
  116. Question for LockRight installers
  117. 1989 4Runner water pump
  118. Heater not workin??
  119. Air Intake Temp Sensor
  120. Suspension lift options
  121. Front main seal
  122. pick-up roof rack
  123. EGR block, why not just...
  124. adjustable camshaft gears(3vze) worth it or not?
  125. need some advice
  126. Steering wheel/column lubrication
  127. pick up with 2 inch lift
  128. Idler arm play
  129. Help!!! Daily Driver Died!!!
  130. Bucket Seats
  131. 95 4Runner Cv axle gouge????
  132. ring & pinion install in DE/MD area???
  133. 1st Post-Body Lift & Roof Rack Done!
  134. Power Light/ Engine Light /Alternator Light
  135. 91 pickup w/ V6 Gears
  136. added seafoam to hot engine
  137. Been 12 years since I've changed a Ujoint...answer a question for me.
  138. 22R - Rebuild? or just buy a whole new motor?
  139. THIS is gonna be an awsome install!
  140. Getting 4 wheels off the ground...tire rotation
  141. whos built there own sub box/center console!?
  142. vsv for cold start
  143. ????
  144. Well boys she bit the big one
  145. Fender Trim
  146. intake off
  147. 91 toyota 4x4 fuel problem
  148. 89' Toyota PU, start then stalls
  149. Finished head gasket today.. results
  150. 87 Engine in 88 Runner (22RE)
  151. fender conversion
  152. Weight of 2nd gen vs 3rd gen 4Runner?
  153. Rust Repair
  154. Burning Lots of Oil & Other Problems
  155. An odd human-machinery bond...
  156. kind of slow
  157. Downey springs
  158. PLEASE help snow coming
  159. I need someone to help...i wanna sell the truck?
  160. Looking For Some Lift Advise
  161. Bleeding oil.
  162. Leak since installing used tranny/dual cases
  163. I know Im a retard but.....
  164. 3vze Auto tranny ATF capacity?
  165. new digi cam first pic what ya think?
  166. Black soot on valve cover
  167. larger bore TB besides DOA or downey for a 3.0
  168. remove tranny with engine??
  169. does any one have a fully independant susp yota??
  170. 3.0 Radiator replacement
  171. where is dan??
  172. HID help
  173. Jay351 & Green93
  174. Seal replacement cost on 95 4runner tranny
  175. who is using Trail gear rear leafs?
  176. Mileage..?
  177. Worth it to keep? (87 4Runner 22RE)
  178. LPG conversion-pics
  179. started after T.C. install, but not now.
  180. Tranny Fluid On Back Window
  181. need help?????
  182. Timing Chain / Engine Noise A Reflection
  183. help with the rig (off-road tech questions)pics
  184. More fuel leaks
  185. tail light part compatablity?
  186. Pressure in the gas tank?
  187. need help on backspacing for 33x14.50x15
  188. adapting 3rd gen cargo cover to 2nd gen
  189. Looky what I found on Ebay near Phoenix
  190. PLease help...94 diff in a 90??
  191. How to bypass ADD with a switch???
  192. Thorley Tri-Y Q
  193. Has anyone tried this header?
  194. 3.0 blowing black smoke like diesel
  195. Limited Slip Question
  196. 22R ticking
  197. truck still smells
  198. Cd Player?
  199. cam question
  200. cv axle issue
  201. idle problems on 22R
  202. My Timing Issues
  203. cold starting and motor storage and pd
  204. cylinder number
  205. Cross threaded spark plug
  206. how many vehicles have you rescued with your rig?
  207. looking for pass fender
  208. Diff breather part. online source?
  209. 3.0 - Is mine rebuildable?
  210. 3vze ? 22re
  211. O2 Sensor Question
  212. My truck is seriously starting to piss me off. Someone help!!
  213. Frozen e-brake, anyone else?
  214. Finally timeto SAS
  215. Remove door panel?
  216. Crank position sensor location
  217. any pics of tires of the ground
  218. 87 22re code 6
  219. I am looking for advice on a small block and SAS swap
  220. How To Fix Richness
  221. Exhaust
  222. jumpy idle and transmission noice
  223. 7M swap, what 5M parts can I use?
  224. 4x4 isnt working
  225. Heat not working...Please Help
  226. Help!! NEWBIE
  227. T100 and mini truck hubs?
  228. power window 88 toy
  229. heater core ? where is it ? 88 4x4 3.0
  230. Seal on manifold
  231. HELP... No oil pressure after HG install
  232. Need some assistance....3vze EFI relay?
  233. Rubbing noise, lower front CV boot
  234. Installing roof rails
  235. loose steering
  236. computer codes how to
  237. battery done backwards
  238. Bodywork and paintwork done!!
  239. e brake adjustment.
  240. 4Runner died, Fuel pump???
  241. Pics from SEMA show
  242. 95 air conditioning into an 88
  243. Side runners?
  244. torsion bar
  245. 1995 3VZE Acting Up.
  246. Dual Steering Stabilizer
  247. Lowering a 95 4runner 2WD
  248. Removing key from ignition...
  249. Parts for Sale
  250. need help to i.d a part.
