Air Intake Temp Sensor
Old Nov 27, 2007 | 02:47 PM
Kiff's Avatar
So I pulled the codes from my 91 4runner. Says my Air Intake Temp Sensor is not working. I checked the FSM but I could not find anything related to a air intake temp sensor. Can anyone help me out? Is it a big deal? The check engine light has not come on during driving, just gave me the code when I checked for it.
Old Nov 27, 2007 | 05:11 PM
84sr5yoty's Avatar
What model, year, and engine do you have?
Old Nov 27, 2007 | 06:56 PM
anotherjeff's Avatar
On both 22RE and 3VZE, the air temp sensor is in the Air Flow Meter. You might want to check to see if it is gunked up.
Old Nov 28, 2007 | 04:34 PM
Kiff's Avatar
1991 4runner v6
Old Nov 28, 2007 | 04:43 PM
BrunswickYota's Avatar
How much does a Air Intake sensor really matter to your rig? What does it exactly do?
Old Nov 28, 2007 | 04:44 PM
Kiff's Avatar
That was going to be my next question, But I'm trying to chase down a horrid gas mileage issue, so I'd like to rule everything out.
Old Nov 28, 2007 | 05:30 PM
4runnerx3's Avatar
Engine temp, air temp and the position of the flap in the AFM all are used to compute the air fuel ratio.
Old Nov 28, 2007 | 06:44 PM
Targetnut's Avatar
I'd suggest to clear the code and see if it returns. The only time I've seen that code is when someone forgot to connect the AFM
Old Nov 28, 2007 | 07:16 PM
dcg9381's Avatar
This can be a huge impact on mileage. The colder the air is, the more fuel you have to add.
I had an issue the other day where the wire to my intake temp sensor died.
My ECU thought it was -40F. It ran rich enough to spit black smoke and partially burned fuel all over the place.. nasty. AFR was off the charts rich.
Old Nov 29, 2007 | 01:19 PM
Kiff's Avatar
How do I clear codes?
the1998sr5
15
Jul 14, 2020 08:35 PM
RatOmeter
Oct 22, 2015 03:17 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
Avenged
Jul 9, 2015 07:55 AM
bryan34w
Jul 6, 2015 05:53 PM
