vsv for cold start
Old Nov 26, 2007 | 06:36 PM
lonestar's Avatar
vsv for cold start
I've searched for bvsv, but I think it might be the wrong name...
On the 22re, its the vsv closer to the front of the motor...
Looks like it goes to the cold start unit.
Don't take this the wrong way, but mine sucks alllllllll the time.
Is that bad?
Where to find?
and or
Do I need it?
thanks
Old Nov 26, 2007 | 06:39 PM
thook's Avatar
Wait...let me recheck this. Be back.
Good lord....what was I thinking? What you're calling your cold start injector is the a/c idle adjustment valve. And that's the vacuum switching valve for it. It's sucking because it runs on vacuum. What seems to be the problem, anyway?
Old Nov 26, 2007 | 10:48 PM
notanymore's Avatar
yeah i dont think there is a vsv for the cold start, there is one for the ac idle and fuel pressure regulator i belive.
Old Nov 27, 2007 | 11:38 AM
lonestar's Avatar
YES YES YES
Your right. Should it be sucking loud enough to hear while the engine is running.
If i don't use the AC right now, would it be ok to cut the VSV out of the loop? Would I need to plug the hose or run it back into itself?
By the way the idle smoothed out a little when I ran it back into itself...
bigjstang
Jun 2, 2025 03:56 PM
BushPig
Oct 29, 2022 06:26 AM
Doug4320
Mar 24, 2018 10:11 PM
Poncho0206
Jul 10, 2015 06:21 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
