PLEASE help snow coming
Old Nov 25, 2007 | 10:42 PM
mxrider8002's Avatar
so i put my 90 toyota 4x4 in 4 wheel drive yesterday and when i started moving there was a consistant clunking noise going with speed. i know its coming from the front end. also i have warn maunual hubs that come on the truck and are they suposed to be pointed oppisite ways of eachother? like one is facing forward and the other is facing back? also could it be cv boots or front driveshafe u joints maybe? help is greatly appriated. its about to snow this week i think and i dont want to get stuck./ thats everyone!!
Old Nov 25, 2007 | 11:19 PM
infiltrator's Avatar
try and give us more info. "clunking" could mean anything. mine sounds like crackles, but im guessing its my joints...
Old Nov 25, 2007 | 11:23 PM
stormin94's Avatar
Check your CV's and then double check them. You may also want to consider checking your motor and tranny mounts. Sometimes if you got a motor mount, or two broke, it'll sound like your engine is gonna hop outta there.
Old Nov 26, 2007 | 01:55 AM
BAZ's Avatar
BAZ
Sounds to me like you need to do a better job pulling out the seeds
Old Nov 26, 2007 | 02:43 AM
isaac338's Avatar
hahahaha.. took me a second to get that one.
Old Nov 26, 2007 | 08:03 AM
hanksyota's Avatar
were you driving on dry pavement?
Old Nov 26, 2007 | 06:01 PM
82yota's Avatar
Have you thought about the joint in the fromt DS? My old 82 did that clunking because that middle joint was never greased as is the problem on quite a few. People just do not know that there are 3 points to grease on that one joint. Not just the U joints. Gotta grease that middle joint as well.
Old Nov 26, 2007 | 06:07 PM
nate V's Avatar
More than likely its your Axle shaft
OR
could be one of your wheel bearings
Old Nov 26, 2007 | 06:27 PM
thook's Avatar
Hey! Mine didn't come with any seeds! Is that good? It smokes an awful lot, too. Is that good? And I think it came from CA.....
Old Nov 26, 2007 | 06:38 PM
Jeenyus04's Avatar
the hubs tell you where to point them. lock is for 4whl free is for 2
Old Nov 26, 2007 | 06:42 PM
yota711's Avatar
U-joints. or you got a bad CV. both easy fixes. and what is this "facing inside and outside" your talking about?
Old Nov 26, 2007 | 07:00 PM
madcelicadriver's Avatar
haveing the same prob it mas my cv joint on my 88
djpg2000
Nov 11, 2020 04:56 AM
itzmywife's
Jul 25, 2015 04:55 PM
keithporter83
Jul 18, 2015 12:37 PM
msane99
Jul 17, 2015 10:13 AM
Odin
Jul 15, 2015 09:28 PM
