power window 88 toy
Old Nov 22, 2007 | 04:53 PM
idanity's Avatar
Talking power window 88 toy **FIXED** thanks.
need to replace the passenger window BUT the motor doesnt work.
i swapped the controls from the working drivers side, still not working.
can the window go down manually .
Old Nov 22, 2007 | 07:12 PM
idanity's Avatar
anyone ?
Old Nov 22, 2007 | 07:39 PM
Tempy T4R's Avatar
Is the motor seized? If it is I think you would have to remove it or loosen it so the gear disengages, then the window assembly should move freely.
I know thats how it is with the tailgate glass anyways
Old Nov 22, 2007 | 08:13 PM
idanity's Avatar
alright, thanks.
anyone know of the voltage the motor uses, i can at least put a battery on it, to see if it will run or not.
Old Nov 22, 2007 | 08:31 PM
nat88toy's Avatar
if you push the window switch and tap on the window motor with a hammer or blunt object of your choise the moter may kick on! has worked for me in the past
Old Nov 22, 2007 | 08:48 PM
thook's Avatar
Originally Posted by idanity
alright, thanks.
Yeah, just run a couple wires (pos and neg) direct from the battery to the motor. Crossing the poles will make it go up one way and down the other. Works on polarity. If the motor won't "click" or move, it's dead. O'Reilly has motors cheap, if you need one. To my knowledge, they won't go down manually.
http://personal.utulsa.edu/~nathan-b.../7powerwin.pdf
Old Nov 22, 2007 | 10:15 PM
idanity's Avatar
thanks
i will try the hammer smack thing, and if that fails, i will try the 12v. (i was just wondering if it worked on anything less, like 9 or 6, w/capacitors somewhere, but if its a 12.v. than im good.
btw,
is there a right/left side motor?
Old Nov 23, 2007 | 04:44 AM
thook's Avatar
I'm pretty sure there is. The part numbers are different, but I believe it's only because of the way they mount. Otherwise, the motors are the same.
If you run a search on toyota power window motors, you'll find there a number of different Toyota vehicles you can use a motor from. But, an easy solution is going to O'Reilly, if you need a new one. They're not "Toyota", but they are not "critical" and they are inexpensive and come with a lifetime warranty. Good bang for the buck.
Old Nov 23, 2007 | 11:41 AM
idanity's Avatar
right on, thats great.
i will be doing this today
Old Nov 23, 2007 | 11:53 AM
DeathCougar's Avatar
You cannot switch left to right motors, becuase of the clocking and position of the motor.
Just hook a battery straight up to the motor, bypassing all the relays and controls. If it moves, you know its not the motor. The drivers side switch cant be used on the pass side. Also, since you have the contoured door panels, make sure you have all the wiring, indlucing the sub harness that goes from the connector to the switch.
I had the same problem in my 89 4Runner (same style door panels as yours) Turned out the pass side swtich was bad. If you have the FSM, it gives you procedures for testing the individual switches.
Old Nov 23, 2007 | 11:54 AM
btw, if it is the motor, or the switch, or whatever the problem is, just come see me at Nix99. I KNOW we have the parts to fix that truck!
Old Nov 23, 2007 | 12:07 PM
Tempy T4R's Avatar
Used parts are the way to go too!
When my tailgate motor died I pulled a passenger side window motor from a wrecked truck at a wrecking yard for $10. Only thing was the tailgate motor uses a driver side type motor so I had to reverse the polarity to make it work correctly.
Old Nov 23, 2007 | 12:26 PM
thook's Avatar
Yep...that's the only requirement by the window motor. Polarity. Well, that and correct voltage.
Old Nov 23, 2007 | 03:35 PM
idanity's Avatar
got the window in
found the motor does indeed work, however, no power to the plug.
i shoved a wire from the lighter into these 2 wires,
and like yall said, about "polarity" is sooo true so, 2 wires, one ground, one hot, and up/down is just a reverse hookup.
thanks everyone. and with the motor still working, i can just re-route these wires now the the dash is out. (i might buy some new molex connectors, even though these look good.)(no corrosion visible)
Jun 1, 2021 01:51 PM
westonian18
May 1, 2020 06:38 AM
okamikai
Apr 30, 2018 10:19 PM
coreyedwards7611
Jan 16, 2016 06:38 PM
Johntom240
7
Jul 13, 2015 12:18 AM
