O/D Off light
Old Dec 1, 2007 | 03:58 PM
Flash319's Avatar
O/D Off light
So I have a 92 runner with auto trans. I just got it on the road and everything was good but now all of a sudden the OD Off light will not go off? It has been cold here for a few days. Does the light come on until the temperature is high enough to allow OD to go on? When I push the button nothing happends. My wife noticed it so I have not drove it far enough to get the trans warm yet but don't know if that is how it works.
I read info on the light and it will flash when there is a problem but I do not have that, just won't go off like it did before when I pushed the button.
Any help or into on this light?
Old Dec 1, 2007 | 07:18 PM
rustypigeon's Avatar
When the vehicle is warmed up does it go into OD? That light should not be on when the switch is pressed in. Like you said a tranny trouble code should cause a flahing light, not steady. Maybe a switch problem, especially if it does not go into OD. Another condition that will cause that light to come on is low voltage. But then you would have a batt light and probably a check engine light as well. (my OD light came on when I snapped an alternator belt)
Old Dec 2, 2007 | 05:41 AM
Flash319's Avatar
I was reading some other stuff and to check the light operation all I have to do is turn the switch on and off and the light should do the same no matter the temperature. I guess I have a short in the switch or something. I will check today and see if it goes into overdrive.
Old Dec 2, 2007 | 07:26 AM
Flash319's Avatar
I found the problem. I wiggled the terminals on the back of the switch and the light started working right.
Old Dec 3, 2007 | 04:04 PM
offroadrunner92's Avatar
my light burnt out , i dont feel like pulling the dash out just to get that stupid 194 in there, i know when its on, lol
Old Dec 3, 2007 | 04:41 PM
Flash319's Avatar
So do I but this is my wifes truck and she would not look for it shifting while driving, I would just get "why is the truck using so much gas". So the light must work..............
Liadrin
Apr 25, 2022 02:54 PM
AkitaDog
Sep 1, 2015 08:05 AM
Liadrin
Sep 1, 2015 06:44 AM
PopsDad1
Jul 30, 2015 02:21 PM
vanion2
Jul 29, 2015 06:17 PM
