PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 [67] 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. 90 3.0 Temp problem
  2. Need help. 3vze problems
  3. Carburetor cover
  4. Timing after belt break
  5. Bumper Fitment?
  6. 22r Crank but no start
  7. I need a new CATALYTIC CONVERTER
  8. I need a new CATALYTIC CONVERTER
  9. Timing off 180* but runs fine?
  10. oversized wheel cylinders and MC
  11. Do these connect? 22r
  12. Im new
  13. The Repair Saga of 'Bradley'
  14. ADD System Clarification -95 4runner
  15. 93 4runner 4wd issue Question
  16. Instrument panel A/D lighting up
  17. installing cam seals 3vze
  18. Longer Pintle cap vs. spray pattern
  19. another mpg thread
  20. Identify Bumper Brand??
  21. guage cluster question
  22. truck will not run or start
  23. Drink holder
  24. 200k Maintenance
  25. dashpot 87 4runner automatic needed?
  26. 22re weird boggy feeling then opens up
  27. A new noise after working on the truck.
  28. fuel guage incorrect
  29. intermittent hum from right front wheel
  30. Warm engine startup stumbling idle 3vze
  31. 90-91 4Runner swing out tire carrier on a 94 4Runner
  32. Truck wont run when warm.
  33. O2 sensor questions
  34. H3 Rims ?
  35. Help with starting problems
  36. Clutch master cylinder bleeding problems ,
  37. 89 Truck-no torque in gear
  38. Tailgate Compatability
  39. Instrument panel lights
  40. Steering wheel/ignition key locked
  41. Raptor 3vze 190 hp
  42. Just SeaFoam'd my 3.slo
  43. intermittent starting issue, NSS?
  44. vent windows
  45. bad ecu?
  46. 3vze wont run when cold
  47. Roof rack
  48. Swapped a 3.0 still smoking
  49. Cam question
  50. 88 4runner Questions Loose Plug
  51. need electrical help
  52. 94 22re ecu, IH1, IH2 pin out needed
  53. Vacuum hoses 4wd
  54. Idle issue getting worse
  55. Timing lights flash vs TDC Mark
  56. What would cause pulling and a "hopping" feel?
  57. Lock Right possible issues
  58. How to clean your speedo cable
  59. Pulled engine - desmog, new timing chain, new engblrdr 268 cam. Poor performance.
  60. 1994 4runner v6 codes 52 and 22
  61. can I put an ac in my 92 yota pick up 4x4 22re didn't come with one
  62. 86 4runner high idle (22-RE 5 speed manual)
  63. '90 22re ECM wiring harness compatible w/ '92?
  64. Cranks but no Start
  65. Help identify a few wires/connectors, please
  66. Tire Pressure... I Know, I Know, Just Read!
  67. 22RE can't go more than 25mph
  68. 3VZE Accel Spark Plug Owners, Please Help!
  69. 22re clutch and timing chain r and r
  70. mx6 shock setting advice ?
  71. Trading a truck for 4 Runner?
  72. windscreen compatibility 4runner
  73. My 3vze is aging.
  74. need the model number of sensatrac for 1988 pickup
  75. Need help on bj spacer ASAP!!!
  76. Loss of Power / Hesitation during pickup
  77. 86 22r project
  78. 88 22re, Code 52, vaccuum, hesitation questions
  79. Would you buy this?
  80. Head Gasket replaced and now sputtering while accelerating
  81. 3VZE 8MM Spark plug wires
  82. 22re bog down
  83. Non ethanol gas.........
  84. 86 4Runner Top Fiberglass Repair
  85. thermostat housing
  86. Need a Megasquirt pro!
  87. 89 Pickup shock question
  88. Headlight Help!!!!
  89. Thx to Yototech
  90. Intake valve problems.
  91. New Engine!
  92. a340H inchworm adaptor install no gears
  93. 1993 4Runner "Jerk" / RPM dropping after Knock Sensor fix?
  94. Dash Lights
  95. Front IFS Locker Shims Needed?
  96. Motor surging problem
  97. Distributor Question
  98. heater fan speed
  99. 2wd fine 4wd gets front end clunk 86 4runner
  100. Clear corner lights
  101. More flex out of rear?
  102. V6 swap?
  103. ADD to manual hub question
  104. 22RE help with these codes
  105. 86 4Runner Brake Issues: Requires pumping always, replaced almost everything
  106. Fuel injector bushing
  107. 86 4Runner stall issues
  108. 88 pickup 4x4 3.0 EFI standard cab check engine light
  109. Fuel injector bushing
  110. 1994 4x4 pickup noise/pulsation
  111. CV Axle Nut
  112. 1988 Toyota intermittent starting issues
  113. will this work......?
  114. Compatibility of fan brackets
  115. 1991 4 runner 3.0 engine problems???
  116. Bought a 93 dlx pickup bogging issue
  117. fuel filter help
  118. Have sway bar link question
  119. 94 4runner quit
  120. New guy with engine swap???
  121. 1986 Toyota 2wd in Vegas, vacuum woes
  122. Anybody tried fender flares from Malaysia?
  123. Led or h4 bulb
  124. Vacuum lines on a 93 Runner
  125. 4Runner wont idle and chugs while driving
  126. Sway bar Q
  127. My First Post: Clutch Noise
  128. worth the money?
  129. 7mge vafm
  130. Need Vacuum Hose Expert Advice. 3VZE
  131. motor swap electrical mess help please !relays?
  132. missing intake ground - troubleshooting
  133. stupid electrical
  134. New guy seeks help! Cant figure it out 87 pickup 22r not re
  135. 94 P/U High Idle, Surge, Coolant Loss
  136. speedometer
  137. Another brake question....
  138. 22R Bad Hesitation While Accelerating
  139. Lift compatibility
  140. 89 4runner no heat
  141. Need help identifying a simple part
  142. Fried igniter?
  143. Rear axle seal leak question
  144. reverse sas
  145. 3vze help
  146. Why Is My Transfer Chain Case Filling Up?
  147. 1987 toyota pickup 22r coolant line
  148. water in oil
  149. camber bolts
  150. Transmission & Transfer case Rebuild Talk
  151. rear quarters 87 DLX fixup
  152. 88 pickup 4X4 high disengages
  153. 88 pickup wont start or run
  154. check engine light not storing a code
  155. Grinding (gear sound) in 4x4 occasional
  156. ** need help asap ** valve adjustment problems
  157. 3.0 random stutter, wont accelerate.
  158. Cv axle shaft replacement question
  159. Tacoma seats into a 3rd gen truck
  160. Weird brake pedal, symptoms...rough idle
  161. I have engine oil in my radiator
  162. high idle coolant problem!!
  163. 92 runner Rail pressuer = 0 instantly when shut off
  164. Lower Control Arm Bolt Removal: Redux
  165. Inner outer Rockers
  166. Leak in radiator
  167. Engine idle and miss
  168. Final check list, am I missing anything?
  169. Squealing in Front of Driver? 89 Truck
  170. Mystery Relay
  171. 86 4runner 22re spark plug threads pulled out
  172. ARB Bumper on Toyota
  173. 94 to 87 bench seat
  174. I am back with a manual transmission question??
  175. What is the switch signal on the CEL chart?
  176. TV 4x4 show
  177. VAFM Cog
  178. 22re - Runs bad after start up - ECM?
  179. coolant is coming out of cab
  180. 89 4 Runner motor swap
  181. 89 4 Runner rear bumper removal
  182. What shock recomended me Rancho or monroe?
  183. Bad front diff bearings or ball joints?
  184. Need info on CV Axel
  185. Replacing BVSV on 3.0L
  186. A340 valve body and accumulator
  187. Miles out of a rebuild
  188. looking for info on these
  189. Broken Temp Sender?
  190. Steering wheel crooked after PS install
  191. 20r made into a 22re help
  192. v6 sr5 burning rich
  193. 94 toyota 3.0 v6 running rough wont idle
  194. 22R Fast Idle Cam - No Spring Tension
  195. Leaking coolant
  196. Another Door retrofitting question
  197. how do i remove 94 4runner grill?
  198. Aussie locker question.
  199. fix or replace rear axel?
  200. 91 v6 wont start, very strange issue
  201. pinon seal for newbee
  202. Dash wiring diagram
  203. Worth going from V6 S12W calipers to S13W?
  204. Fuel position sensor
  205. 1990 Toyota 4runner humming noise
  206. 88 22rte misfires from 2000-2500rpm
  207. Bad wheel hop.
  208. 93' 5 speed pickup Any Info would be appreciated!!!!
  209. 91 pickup having trouble going from 4x4 to 2x4
  210. Will this work?
  211. Timing on my 22RE
  212. Roof racks for pick-up ?
  213. A340H without 3vze ECU - will it work?
  214. 89 p/u 3.0 slave cylinder
  215. Rough Idle after slamming brakes - 94 4runner V6 4x4 auto
  216. My nightmare came true today.
  217. 89 3.0 lockers sas
  218. MPG, Cold air intake and POOGS??
  219. hairline crack rear diff housing
  220. blown coolant out and not heat
  221. Oil leak
  222. 3rd member blues
  223. Dead FSM links? Im looking for fsm 1995 3.0
  224. Engine Swap
  225. What length shackle are you running for your 63" swap?
  226. Why does my 88 Pickup shut down on the freeway?
  227. '93 Pickup with 22re swap: DEQ HELP!
  228. New (to me) 4 runner, new to forum
  229. Wiring Harness compatibility '92 4x4 22RE
  230. Starter grinds, starts after 2-10 tries
  231. What is best Head Gasket for 22re?
  232. Engine Swap sticky
  233. sr5 Cluster acting funny
  234. circuit opening relay question
  235. Need some help
  236. New Axles and bearings on an IFS
  237. DIY mudflaps?
  238. Exhaust System Replacement 1989 22RE?
  239. Tuning Weber 32/26 on 22R went wrong. Engine Pressure Buildup
  240. Advice for someone looking to buy a 84-89 4Runner
  241. GM Alternator Swap - Questions
  242. 87 pickup idle problems
  243. 1990 22re upper radiator hose and intake hose
  244. Head Gasket Blown after 3k? Coolant loss
  245. A strange fix...
  246. 2nd gen tailgate regulator in 1st gen 4runner
  247. What do you think of these TPS numbers?
  248. Landed a free 92 4runner need advice
  249. Manual Hub Parts - Best place to get?
  250. 91 v6 wont start, very strange problem
