hairline crack rear diff housing
Old Jan 8, 2014 | 09:04 AM
desert-stew's Avatar
have a 97 4runner sr5 2wd and just replaced the seal to the 3rd as it was leaking. well, it was still leaking....did closer inspection and the housing itself has a hairline crack....options?
1. i imagine a replacement housing would be expensive not to mention the labor on top?
2. can it be welded? probably a short term fix
its my daily driver with 280k and i dont go offroad....any advice would be appreciated.
thanks!
Old Jan 8, 2014 | 09:26 AM
v_man's Avatar
I'd weld it up , both sides if you can reach 'em , and keep an eye on it .
How thick are those housings ?
Old Jan 8, 2014 | 11:57 AM
highonpottery's Avatar
location/pic of the crack in the housing?
Old Jan 8, 2014 | 11:59 AM
thefishguy77's Avatar
Weld it up to get you by till you have time and money to swap a lightly used one in.
Old Jan 8, 2014 | 12:09 PM
Stuwy123's Avatar
Rear axles are pretty easy to swap.
Unbolt the e-brake, brake lines and abs sensor.
Then cut the u-bolts. Don't waste your time with unbolting them.
Insert new axle and install new U-bolts.
Old Jan 8, 2014 | 01:25 PM
wyoming9's Avatar
Red face
Why did it crack??
Was it a flaw in the casting??
Just where is the crack?/
If your going to weld the housing and some one like me does it The repair will outlast the truck.
Old Jan 8, 2014 | 01:56 PM
HighLux's Avatar
Braze it up. Weld it up?? lol.
jerusry
Oct 19, 2015 05:28 PM
Daneums
Aug 20, 2015 05:36 AM
A2theK
Jul 12, 2015 10:46 AM
Poncho0206
Jul 10, 2015 06:21 PM
horunner1x
Jul 10, 2015 06:33 AM
