stupid electrical
Old Jan 15, 2014 | 04:24 PM
Goubenator's Avatar
stupid electrical
ok so a couple months ago i got a new alternator (O'reilys) ive been having a problem of my battery light and my brake light flashing at me on my gauge cluster, when i turn on my blinker (left or right) my radio shuts off and my interior lights shut off for a split second then comes back on and my voltmeter does drop when all this bs is going on. i just replaced my battery which seemed to help for like a day. ive checked my grounds and everything like that no problems that i see does anyone have any input. ive been told that i could have gotten a bad alternator? would that make sense?
Old Jan 15, 2014 | 05:09 PM
RAD4Runner's Avatar
Did you thoroughly double-check your connections?
Do your connections have bare metal contacting bare metal, not gray metal?
Do you have a volt-meter? Next to our senses, that is the best and most important troubleshooting tool- especially for stupid electrical - LOL!
See my signature for test points to help you narrow down the problem in stupid charging system.
Old Jan 15, 2014 | 05:10 PM
milkybar's Avatar
Check for a short. Fault may be unrelated to alternator install.
Old Jan 15, 2014 | 05:16 PM
RAD4Runner's Avatar
Yep, that, too. A short would drop your Voltage very low. So you really need a multi-meter.
...when i turn on my blinker (left or right) my radio shuts off and my interior lights shut off for a split second
It does not happen when you turn on your headlights? Then, yes like Milky bar says^^^
IF and only IF it happens ONLY with blinker and not other lights, yes, likely a mild (Not zero ohm to ground) short in blinker circuit.
Which side blinker makes it happen? Focus on that first. Check trailer towing harness if installed, blinker sockets and wiring for shorting to ground.
Old Jan 16, 2014 | 11:56 PM
wyoming9's Avatar
Red face
You replaced the alternator ?? Now the battery ?/
You checked the grounds ?? Just how did you do this??
So the charging system problem light comes on when the turn signals are used.
What is your system voltage ?? Bottom line your charging system is unable to handle the extra demand on the system when turn signals are used.
Poor connections . aged brittle cables
Corroded light sockets or bulbs adding to the load of the circuit.
Just what is it your working on??
Obmi
Oct 4, 2015 11:30 AM
voiddweller
Oct 2, 2015 07:47 AM
PNW94Runner
Sep 29, 2015 02:55 PM
Rickstwowheels
Sep 29, 2015 02:23 PM
voiddweller
Sep 28, 2015 11:21 PM
