heater fan speed
Old Jan 19, 2014 | 07:58 AM
chicagopetedagreek1's Avatar
heater fan speed
89 22re 4x4 pick-up, again nothing in the Haynes repair manual, ....where is the resister that controls the fan speed? it only works on high
Old Jan 19, 2014 | 08:58 AM
Discombobulated's Avatar
should be by the blower motor, passenger side attached to the firewall. Pretty easy to replace.
Old Jan 19, 2014 | 10:26 AM
thanks Dis. I'll try to find it
Old Jan 19, 2014 | 10:30 AM
wyoming9's Avatar
Red face
I know on the 87 Trucks it is mounted on the heater box.
Should be pretty easy to see.
I think you need to remove the glove Box but I am not real sure.
Old Jan 19, 2014 | 11:15 AM
Yes glove box comes out, when I got mine done I had my mechanic do it when he was doing my ac conversion pretty sure it's just the plug and a couple of screws. It was well worth it though my 2 low settings were gone and it was melting my face or trickling out just from the fresh air setting.
Once you dig in it will be pretty straight forward
Old Jan 19, 2014 | 11:53 AM
RAD4Runner's Avatar
Yeah, probably the resistor- inexpensive and very simple to replace. ON the 1986-1988 22R-E 4Runners, Location and test points (IF you need to troubleshoot) are on my post here.
Sorry, not sure if 89 is same as 88, but electrical concept should be the same.
Old Jan 20, 2014 | 08:12 AM
got-er done, didn't have to remove glove box or blower motor, just unplugged & removed da 2 screws .....Thanks Guys !!!!
Old Jan 21, 2014 | 09:39 AM
derockus's Avatar
related threadjack:
My fan (89 DLX 4Rnr) only works on high speed as well. Except "high" is a joke and feels more like the medium-low speed. Will swapping this resistor fix the lost speeds and bring my overall fan speed back up?
Old Jan 21, 2014 | 10:23 AM
RAD4Runner's Avatar
Originally Posted by derockus
related threadjack:
Most likely.
Maybe yes, maybe not. Problem could also be with your blower fan motor. However, just do it. (Replacement Resistor is inexpensive):
  • Take resistor out, inspect and and test it. Replace if found defective. A defective resistor (too high a resistance or poor connection) will cause slow fan speed, so replacing a bad one may also may fix your weak high speed issue.
  • Take out fan and clean it, check motor for binding.
    Whatever you do, this is a good opportunity to understand that system. Once you have access to the suggested test points on my post ^^^, try them.
Old Jan 21, 2014 | 11:51 AM
the resister for my 89 pick-up was $41.00 & some change from autozone, now I have 4 fan speeds, not just high !!!!
Old Jan 21, 2014 | 02:03 PM
RAD4Runner's Avatar
12 to 18 bucks at RockAuto
Old Jan 22, 2014 | 08:20 AM
Rad, looked up the part #87138-89105, at Rockauto, for my 89 pickup, it was 34.99 + shipping + taxes, comes out to about what I paid at Autozone, & I didn't have to wait
Old Jan 22, 2014 | 10:34 AM
RAD4Runner's Avatar
Hmmm... I paid $14.19 total for my 1986 4Runner, 22RE, DLX
maybe different for the 1986 trucks?
the1998sr5
15
Jul 14, 2020 08:35 PM
BeMiceElf
Oct 10, 2015 09:40 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
vanion2
Jul 29, 2015 06:17 PM
jjrbus
Jul 19, 2015 02:06 PM
