fix or replace rear axel?
Old Jan 10, 2014 | 10:04 AM
94_Bama's Avatar
I have a 94 22re pickup 4wd,
I took it to a local mechanics personal shop about a month ago needing a couple of things checked out. The biggest was i had zero dope in the rear end and wanted all seals replaced. Well i called them today and they finally admitted that they have yet to work on anything (month long and havent touched it!) But they told my the rear end needed all seals and bearings replaced. Told me they can either order all the parts and replace them or they can swap out the axel with one the one of the mechanics has on a parts truck (told me the axle is the same including gear ratios)
Long story short, my question is which option would be better/ cheaper?
Any advise would be much appreciated.
P.S. sorry for grammatical errors
Old Jan 10, 2014 | 10:30 AM
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
go for the new bearings, seals, and diff fill. You have no idea bout the condition of the barings and sals rear end from the parts truck, or when the diff was drained and refilled. AND, you won't have to just take his word on if the gears in the pumpkin matching the front end gears.
I'd go for the new bearings and stuff, if it was me......
Old Jan 10, 2014 | 10:39 AM
94_Bama's Avatar
Thanks, it just pi$$es me off that theyve had it for a month now and havent touched the dang thing... if i would have known it would have taken this long i would have done it myself..
Old Jan 10, 2014 | 10:49 AM
v_man's Avatar
Man that is so frustrating . Slow mechanics are the worst , a month is outrageous .
How long did he say it would take when you dropped it off ?
I'd go new seals / internals / fluids on your axle ...
Old Jan 10, 2014 | 10:50 AM
I don't blame you on that, I'd be more than pissed!
Old Jan 10, 2014 | 11:04 AM
94_Bama's Avatar
They didnt day but i would have never thought it would take this long for seals... when i finally talked to the they asked me what all it was i wanted done, which i told them when i dropped it off and also wrote it down for them... with my phone number to call if they had any questions...
Im very pissed, i need a lot more work done but i will not have them do it, i will take it else were...
Old Jan 10, 2014 | 12:05 PM
94_Bama's Avatar
Just got off the phone with the guy, got the chunk broke open and its no good... Broken teeth, ripped seals said that he has another diff on hand and will break it open and see if he can swap it. said that it was filled with water, a little dope and "something else" guessing previous owner put something in it to keep it running long enough for me to buy it... but they do have all the parts and will be fixing today.
voiddweller
19
May 2, 2016 09:10 PM
Jmiller1023
23
Aug 6, 2015 07:03 PM
merc1100sc
Jun 26, 2015 05:24 PM
cchinny
Jun 25, 2015 08:11 PM
infinityisfive
Jun 16, 2015 06:51 PM
